Anyone Interested?
Old Jul 6, 2006 | 12:22 PM
Tech6023's Avatar
Default Bseries galore allmotor stuff NEW PRICES
Im debating whether or not I want to part out my current project, I dont have the time with school, work, friends. Ive had this paticular car for 2 1/2 years, its been sitting since feb of last year, I really hate posting this stuff but other things need to come first
92 Hb shell, I think its a Cx? its the very base model with no side molding holes, its white, it will need a r. fender has a little ding and and a scrape above the fender well, the ignition is busted, the interior is gutted except for door panels, dash, carpet. under the engine bay is painted semi gloss black, where the hatch struts mount up is damaged, I bought it as a theft recovery and I took it through inspection. It has tokico 5ways with H&R race springs, Jdm Itr rear sway bar and Civic Sir G front sway bar and weld on rear lower bar with gsr brakes w/new front honda pads and brembo cross drilled rotors and a SI prop valve, will also include a Integra boster and master. Has Bseries mounts. I think $1300 is a fair price
2000 Itr block, includes caps and girdle,oil pump, oil pan, block is set up for and endyn style breather kit, Has vin tag. and a fresh Hone, only had a few thousand miles. $500 I have a Gsr crank thats at the machineshop getting rebalanced, has bearings sized for that block
2001 Itr head, no cams, no distributor, Includes caps, valves, springs. $500
JG PR3 pro series head, Itr outer springs with portflow inners, check Jgs website for the specs. $900
Bc4 cams with Skunk gears, 2k miles, still have boxes $550
samco blue rad hoses for Dc2 r, or eg if trimmed, new $95
Megan 4-1 header new, has couple dings $100
Rockect gen 2 springs and retainers New $260
Acl rod bearing, B18c $30
Ctr pistons std with rings and pins new $285
Itr Rods resized with apr bolts, New $250
used itr pistons and rods $100
2 Red sparco Evos, say 7-10, no burns no holes, on sparco brackets with dc/eg rails, only problem is the plastic trim pieces keep popin off, I think $700 for the pair might be fair
SRR pedal set $30 new
SRR bumper release $30 new
Srr harness Blue $100 for the pair
b16 intake 2nd gen $50
I think I have a Itr Tb $125
Jg outers with aluminum retainers $30 used
Eg ex harness with knock wire added $75 fresh tape
P28 $125
P72 obd1 $175
Type r trans, Rebuilt, Zero miles, all new bearings, syncros laped, any problem I will refund your money. $1200
I will add more as I think about it
Every thing I got came to me as legit, I am a tech at Lynnwood honda so I cant be dealing with stolen stuff
NO TRADES! i am getting out of hondas for now
I am trying to see if I can get any intrest at a fair price.
Modified by Tech6023 at 8:44 PM 7/6/2006
Modified by Tech6023 at 8:50 PM 7/6/2006
Modified by Tech6023 at 7:38 AM 7/7/2006
Modified by Tech6023 at 12:14 PM 7/7/2006
Modified by Tech6023 at 1:03 PM 7/8/2006
Old Jul 6, 2006 | 01:48 PM
2000Accord5sp's Avatar
not technically a trade but since I assume you are selling the struts/springs on the car because you don't have replacements. Would you sell them to me if I give you stock shocks/springs? if so, how much?
Old Jul 6, 2006 | 01:54 PM
Tech6023's Avatar
Default Re: (2000Accord5sp)
No i cant seperate, the car has been sitten at a friends parents house for a year and they want it gone
Old Jul 6, 2006 | 03:36 PM
Tech6023's Avatar
Default Re: (Tech6023)
All so have Homemadeturbo.com Itb's $300 exact one on there
Rc 310 injectors, need orings
couple b series valve covers
b series linkage
shortshifter
focuz custom test pipe/ resonator 2.5inch
Old Jul 6, 2006 | 06:01 PM
Tech6023's Avatar
Arp head studs new $100 b16/c5
Assco flywheel used $150 same one heel toe sells
2nd gen vtec head sprayers $10
2006 civic ex rims $50
More stuff http://hondamarketplace.com/zerothread/1680328
Modified by Tech6023 at 8:46 PM 7/6/2006
Old Jul 7, 2006 | 06:44 AM
Tech6023's Avatar
Default Re: Anyone Interested? allmotor stuff NEW PRICES (Tech6023)
Bump
Old Jul 7, 2006 | 10:18 AM
Typer#23's Avatar
tranny still for sale?
Old Jul 7, 2006 | 10:54 AM
Tech6023's Avatar
Default Re: Anyone Interested? allmotor stuff NEW PRICES (Typer#23)
Yeah I still have it, us spec, rebuilt by me, all new Honda bearings, all syncros checked and laped, if ya have any problems with it I will refund you money and give ya 100 bucks since the trans has zero miles
Old Jul 7, 2006 | 02:12 PM
Tech6023's Avatar
bump
Old Jul 7, 2006 | 02:13 PM
Typer#23's Avatar
1150 ill buy it. does it have stock clutch? 425-445-2388
Modified by Typer#23 at 3:52 PM 7/7/2006
Old Jul 7, 2006 | 03:25 PM
Tech6023's Avatar
I also have a bunch of Hydro trans parts, case's, diff's, gearsets' counter and main shafts. let me know what you need. gsr,b16,Ls
Old Jul 8, 2006 | 12:03 PM
Tech6023's Avatar
Bump
Old Jul 8, 2006 | 07:37 PM
kid vtecnik's Avatar
Default Re: Bseries galore allmotor stuff NEW PRICES (Tech6023)
i like to pick up those radiator hose's pm me please
Old Jul 9, 2006 | 10:23 AM
Tech6023's Avatar
Default Re: Bseries galore allmotor stuff NEW PRICES (kid vtecnik)
There pending sale, I will let you know
Old Jul 9, 2006 | 09:16 PM
Tech6023's Avatar
Bump
Old Jul 9, 2006 | 09:51 PM
willywong's Avatar
still got those buddy club cams?? how much for just the cams?? spec 4 right??
Old Jul 9, 2006 | 10:09 PM
red808teg's Avatar
bump for the arp head studs, hows 90 shipped hit me up
wesyoung03@yahoo.com
Old Jul 10, 2006 | 06:44 AM
Tech6023's Avatar
Default Re: (red808teg)
Pending sale for $100
Old Jul 13, 2006 | 08:51 PM
SlammedDC2's Avatar
Semper Fidelis
PM'd
Old Jul 13, 2006 | 10:01 PM
TheThiefTheKnife'NTheGun's Avatar
Default Re: (SlammedDC2)
PM sent
Old Jul 13, 2006 | 10:46 PM
Sector9guy's Avatar
Default Re: (TheThiefTheKnife'NTheGun)
pm'd.
Old Jul 14, 2006 | 08:12 AM
JDM Panda's Avatar
The head n studs still for sale?
Old Jul 16, 2006 | 01:32 PM
Sector9guy's Avatar
Default Re: (JDM Panda)
bump cuz i want to know whats up with the head
Old Jul 16, 2006 | 01:49 PM
JDM Panda's Avatar
Default Re: (sector9guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sector9guy &raquo;</TD></TR><TR><TD CLASS="quote">bump cuz i want to know whats up with the head</TD></TR></TABLE>
same
Old Jul 17, 2006 | 10:59 AM
JDM Panda's Avatar
No longer need the head or studs.
