b series/d series transmission parts/case's !!!!
Old Jul 6, 2006 | 04:56 AM
DaveF's Avatar
Default b series/d series transmission parts/case's !!!!
new thread....
Modified by dturbocivic at 3:09 PM 9/16/2006
Old Jul 18, 2006 | 02:32 PM
DaveF's Avatar
Default Re: b series/d series transmission parts/case's !!!! (dturbocivic)
bump for meeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Old Aug 18, 2006 | 05:04 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">misc b series/d series trans case's....
1 d series hydro case/gearset *best offer*
2 b series cable, small spline case outer *50 plus shipping*
1 b series ls cable gearset small spline *best offer*
2 hydro bseries bellhousing/inners *150 plus shipping*
2 hydro LS gearsets/shift forks/differentials' *SOLD SOLD SOLD* mostly complete trans minus case halves and shifter mechanism.
first up
1..dseries hydro case. this trans has a blown diff, but the gearset is hopefully still good. i never pulled it apart.
2. this is a bseries cable *LS*trans, small spline. the outer case is good, the inner case has a hole from the diff, the gearset should be ok.havent pulled this one apart either
3. here are 2 inner's and 1 outer, the 2 inners are for b series hydro, the outer is a bseries cable, small spline outer(only 2 shift forks)
this is the case with the green vin tag on it, the previous owner poked the 12mm bolt through where the shifter stabilizer bar bolt on.
this is the inner b series hydro case with sticker tag on it.
Modified by dturbocivic at 6:32 PM 7/18/2006</TD></TR></TABLE>
Old Sep 16, 2006 | 04:20 AM
DaveF's Avatar
bump
Mfoehrkolb
Sep 15, 2011 08:16 PM
skunk2powered
Sep 17, 2004 09:44 PM
98HB
Oct 29, 2003 04:58 AM
