Mini Me (d16z6) Distributer Question ??
Old Jul 5, 2006 | 09:17 PM
splagga's Avatar
Default Mini Me (d16z6) Distributer Question ??
Hey I just bought a 90 Si CRX with a D16z6 motor in it. It's missing a distributor plug wires and ECU. I was wondering if I could use the OBD0 distributor and ECU and wires adn if so will the car start and work good ? HELP !!!!!!!!!!!!!
Old Jul 5, 2006 | 09:30 PM
Maxpower350's Avatar
Default Re: Mini Me (d16z6) Distributer Question ?? (splagga)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splagga &raquo;</TD></TR><TR><TD CLASS="quote">Hey I just bought a 90 Si CRX with a D16z6 motor in it. It's missing a distributor plug wires and ECU. I was wondering if I could use the OBD0 distributor and ECU and wires adn if so will the car start and work good ? HELP !!!!!!!!!!!!!</TD></TR></TABLE>
if you were to use the Obd-o dizzy(distribator) you would have to cut the legs of the sizzy to fit the Z6 housing, for the ecu yes you can use the stock one,pm6 if you have obd-o injectors,
is it a full swap or is it just a Z6 block and head with A6 intake and injectors. More like do you see a shiny silver box at the corner that is a resistor box for the obd-o injectors.
Old Jul 5, 2006 | 09:41 PM
pinecone's Avatar
Default Re: Mini Me (Maxpower350)
Get the z6 dizzy (TD-42U) and get a dizzy conversion harness from Rywire.com
Plug wires you can use an D-series wires atleast.
Get the P28 for OBD1 and Vtec capabilities.
Kris's turbo
Apr 24, 2012 11:10 AM
dr_latino999
Jul 25, 2005 06:12 AM
phatboi
Apr 11, 2005 06:40 PM
D124gOn
Mar 7, 2003 01:34 AM
jdm_ef9
Dec 8, 2001 07:16 PM
