97 Base Boggs thru turns at wot, any ideas?
Old Jul 5, 2006 | 09:14 PM
DC 2's Avatar
Default 97 Base Boggs thru turns at wot, any ideas?
97 Base model prelude stock except for susp setup.
The car will bog mid way thru a mildly sharp turn at wide open throttle like its hitting a rev limiter around 6k. The car has a full tank of gas and preforms fine on straights so I need some ideas.
Thanks in advance.
Old Jul 5, 2006 | 10:38 PM
bad-monkey's Avatar
Default Re: 97 Base Boggs thru turns at wot, any ideas? (DC 2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC 2 &raquo;</TD></TR><TR><TD CLASS="quote">97 Base model prelude stock except for susp setup.
Thanks in advance.</TD></TR></TABLE>
sounds like oil starve.
Old Jul 6, 2006 | 09:51 AM
vtecjb's Avatar
definitely low on oil. sounds too easy but thats most likely ur problem just try putting a quart or so in and let us know how it goes.
Old Jul 6, 2006 | 09:55 AM
HS2G's Avatar
Default Re: 97 Base Boggs thru turns at wot, any ideas? (vtecjb)
If its not that maybe a misfire?
Old Jul 6, 2006 | 10:00 AM
vtecjb's Avatar
possibly but that wouldnt explain why it only does it during cornering
Old Jul 6, 2006 | 10:05 AM
A Blue Lude's Avatar
Default Re: 97 Base Boggs thru turns at wot, any ideas? (bad-monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">sounds like oil starve.</TD></TR></TABLE>
Old Jul 6, 2006 | 11:06 AM
Chuckles99SH's Avatar
Default Re: 97 Base Boggs thru turns at wot, any ideas? (A Blue Lude)
I just had the exact same problem with my 99sh i was just under a qrt low. I would corner hard and open it up and it would sound like my rev limiter and jerk me towards the dash.
Old Jul 7, 2006 | 11:51 AM
DC 2's Avatar
Default Re: 97 Base Boggs thru turns at wot, any ideas? (Chuckles99SH)
Yall were on the money, she was def low on oil.
It amazes me how much it consumes, never leaks a drop.
1.5qts low.
&lt;dissapointed in myself.
Thank you
urv8islow
Apr 25, 2010 04:12 PM
xonn
32
Dec 6, 2006 06:21 AM
bchomka
Nov 21, 2004 10:31 AM
LouisianaCivic97
Sep 27, 2004 07:30 AM
