gsr edel. mani. vacs
sorry couldn't find camera at this time of night so used camera phone
, upon installation, there are a bunch of holes in the back, i don't know which one is which but here is the order i put them: (correct me if i'm wrong or missing anything)
n/a, n/a, bov sensor vac, pvc, brake booster, boost gauge, fpr
and there is a bunch of lines that lead to the secondary throttle, i don't know where they go or if needed, the problem is there are two sensor plugs that go in each.
hint or suggestions would be helpful.
, upon installation, there are a bunch of holes in the back, i don't know which one is which but here is the order i put them: (correct me if i'm wrong or missing anything)n/a, n/a, bov sensor vac, pvc, brake booster, boost gauge, fpr
Just hook all your vacuum sources up to the right sized nipples and cap off the rest. There is really no order.
The lines in the second pic are just junk from the IAB system. You don't need to hook those up.
for the vac sources, it doesn't really matter.
1.BOV
2.plugged
3.down to that small black cannister below battery
4.wastegate
5.fmu (if you're using one) or catch can
6.break booster
7.boost guage
8.FPR
reference: http://www.paccoasttuning.net/...92b7d
just make the lines sizes match to the fitting.
it's pretty much up to you.
1.BOV
2.plugged
4.wastegate
6.break booster
7.boost guage
8.FPR
it's pretty much up to you.Thread
turbotime
Oct 6, 2005 11:30 AM
