Del Sol wiring problems
Old Jul 5, 2006 | 05:06 PM
azoodica's Avatar
Default Del Sol wiring problems
Well the previous owner decided to rip up the interior so its a mess and now the driver's side window and backwindow doesn't roll up
fuses are okay
don't know about the power but the connections are fine
any ideas?
Old Jul 5, 2006 | 05:49 PM
sohcvtec1995's Avatar
the window motor? it could be off track? can you take a pic so we can see what your looking at?
Old Jul 5, 2006 | 08:41 PM
jdeemseerx's Avatar
the easiest way of going about that would be to take off the drivers door panel and test the regulator motor and start from there.. get a test light, and connect it to a good ground. Unplug the connection to the window motor and probe the harness side that isnt connected to the motor.. with the switch pressed down and the key on you should have power and ground one way, and then with the switch up, you should have + and - reversed.. see if that checks out and we'll go from there.. Hope this wasnt too much of a rant to understand
96civic808
Dec 20, 2015 03:27 AM
Ju1cesk8er
18
Aug 13, 2012 04:13 PM
bigsmoketeg
Jun 25, 2010 06:49 PM
jrod95cpe
Mar 3, 2010 01:58 PM
surferdude
Oct 17, 2008 03:56 PM
