motor options OE motor has si 300,000 miles and its slow as !!!!
Old Jul 5, 2006 | 03:37 PM
Name Removed's Avatar
(Banned)
Default motor options OE motor has si 300,000 miles and its slow as !!!!
I have an 89 si.
the OEM motor has 300,000 miles car is very slow. I can't keep up with traffic.
So I am looking into swapping it out for a jdm zc single head or something similar maybe a usdm ex.
which would be the best choice. My si tr-any is mint so I would only need the long block. I am an si so its easy for me to go obd1 or 2 if I have to. I want to keep my ac so I would need a motor that can run it.
but anyways will I still be able to use my current oem mounts from the d series.
I have swapped k,b series motor but never a d series. Since this is my daily driver and I quite frankly don't know much about mini me and **** like that.
please let me know the best options I have.
Old Jul 5, 2006 | 03:40 PM
Jesterian's Avatar
24.243.141.75
Default Re: motor options OE motor has si 300,000 miles and its slow as !!!! (FUCKREDNECKS)
You should at least be able to "keep up with traffic", I would suggest simply figuring out what is wrong with this motor if you aren't looking for extreme performance.
Old Jul 5, 2006 | 03:48 PM
Vantage's Avatar
After 300,000 miles id say its time for a new engine. Good engines of choice are...
d16a6 ( same as stock engine) - 106hp
JDM Sohc ZC - 120hp
D16z6 - 125hp
D16y8 - 127hp
DOHC ZC - 129hp
JDM d15b - 130hp
Im not 100% on my HP #'s but they are close. Each engine has its ups and downs.
If u want an easy swap with a bit more HP, the SOHC ZC is the JDM version of your a6, with a more aggressive cam and a bit more compression, and will drop straight in to my knowledge. ( no wiring changes needed).
All the other engines require slighty changes but nothing significant, wire Vtec, or a few wires for DOHC ZC. all of these engines will be more zippy than your stock engine, and have a wide variety of aftermarket support (less so for d15b/DOHC ZC) though MOST! parts are interchangable.
check out hmotorsonline for DOHC/SOHC ZC's and d15b.
If can always go obd1 if u play to get carried away with the car, but if its just gunna stay near stock, id suggest keeping it obd0.
Then there are always B swaps, they are always something to consider.
Old Jul 5, 2006 | 03:52 PM
(Banned)
Default Re: motor options OE motor has si 300,000 miles and its slow as !!!! (Jesterian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jesterian &raquo;</TD></TR><TR><TD CLASS="quote">You should at least be able to "keep up with traffic", I would suggest simply figuring out what is wrong with this motor if you aren't looking for extreme performance.
you are right. but there is nothing wrong with my motor. it has 300,000 + miles.
tranny doesn't grind its just slow. It doesn't burn a bit of oil. Compression test was 165+ on all 4 cylinders. I was talking to someone he suggested the cat might be clogged!!!
I am going to take it off and see what happens. but I just passed smog in CA so I don't see the cat being the problem.
Old Jul 5, 2006 | 04:02 PM
(Banned)
Default Re: (B18a_CRX)
dont want to spend much on the swap. I had a b series swap before they are fun. I have a k24 integra so I don't want another swap. My daily driver can't afford to get pulled over with that car and get a ref ticket.
Old Jul 5, 2006 | 04:12 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Default Re: (FUCKREDNECKS)
Just rebuild the stocker then, will cost you sub $500 and less than a week of downtime
I doubt you have this k24 integra though if you are uneasy about swapping in a d16
Old Jul 5, 2006 | 04:21 PM
(Banned)
Default Re: (PINKS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PINKS &raquo;</TD></TR><TR><TD CLASS="quote">Just rebuild the stocker then, will cost you sub $500 and less than a week of downtime
I doubt you have this k24 integra though if you are uneasy about swapping in a d16</TD></TR></TABLE>
rofl. I swapped more motors that you can imagine. I never swapped a d series motor like I said before. I didn't say I was uneasy about swapping a d16 motor I said I don't know whats required say mounts wise.
Old Jul 5, 2006 | 04:28 PM
PINKS's Avatar
grab a sohc zc, $300 locally, direct swap ZERO modifications...
Throw on a new clutch and youve got another 200k coming at you
Sounds like what you need
Old Jul 5, 2006 | 04:37 PM
(Banned)
Default Re: (PINKS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PINKS &raquo;</TD></TR><TR><TD CLASS="quote">grab a sohc zc, $300 locally, direct swap ZERO modifications...
Sounds like what you need</TD></TR></TABLE>
yea I am going to take off the cat and see if that **** is clogged. I think that might solve my problem.
Old Jul 5, 2006 | 04:46 PM
Vantage's Avatar
if ur tranny doesnt grind, and ur engine has 165psi compression, ur problem isnt the engine or tranny. Id start looking elsewhere, as u said, a cat could be holding it back, maybe ur clutch is toast?
Old Jul 5, 2006 | 04:51 PM
(Banned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18a_CRX &raquo;</TD></TR><TR><TD CLASS="quote">if ur tranny doesnt grind, and ur engine has 165psi compression, ur problem isnt the engine or tranny. Id start looking elsewhere, as u said, a cat could be holding it back, maybe ur clutch is toast?</TD></TR></TABLE>
haha my clutch is gone!! can that be the reason for the car to be slow??
Old Jul 5, 2006 | 05:18 PM
PINKS's Avatar
Thats the reason sir
Old Jul 5, 2006 | 05:50 PM
(Banned)
Default Re: (PINKS)
sweet.
ron
Evolution-93-Ex
Mar 20, 2006 12:31 PM
stockcrix1616
Aug 21, 2003 01:53 PM
spicy mike
10
Nov 11, 2002 03:18 PM
Loaded Butane
Sep 5, 2002 10:15 AM
