how high is too high for turbo?
how high of compression can you have to safely run a turbo setup.
this is why i asked, i had a local shop rebuild my engine and here is a list of what the done:
bored
honed
eagle crank
aries 12:1 pistons
stock rods
port and polish
5-angle valve job
converted chambers
the only thing that i'm not happy with is that they talked me into getting those pistons and now i have a high compression non-vtec b18, but i want to work with what i've got and i want to turbo. is this possible?
if it is possible, it will be low boost and small turbo.
<shane>
Modified by Dasani at 4:27 PM 7/5/2006
bored
honed
eagle crank
aries 12:1 pistons
stock rods
port and polish
5-angle valve job
converted chambers
<shane>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dasani »</TD></TR><TR><TD CLASS="quote">
bored (i believe it to be 1.95) </TD></TR></TABLE>
That makes no sense, 1.95 what? That cant be the bore size cause that would be small *** pistons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dasani »</TD></TR><TR><TD CLASS="quote">aries 12:1 pistons
stock rods
Those 2 plus turbo will equal S shape rods or snapped rods.
If you upgrade your rods and get AEM EMS or something of that nature and a very good tuner then yes you could do it no problem.
stock rods
Thats pretty high. I personally dont know anyone with a turbo car with that kind of compression.
If you really want to go turbo, I'd just get a thicker head gasket to bring the comp down.
fuel management will be no problem. i already have AEM filter, regulator, rail, and i'll be running a hondata s200.
and i already have a thicker headgasket, but what kind of rods should i run?
t25 turbo was what i would be running because thats what i already have.
and by bringing the comp down, i would have to replace the pistons. Right?
7rrivera7
May 28, 2007 02:38 PM
