Del Sol Suspension Problem
Old Jul 5, 2006 | 07:30 AM
majinx4's Avatar
Default Del Sol Suspension Problem
When i push down on my driver side or go over bumps something in my suspension is squeeking really lound, almost like metal rubbing on metal, it also sqeeks really loud if i'm sitting still and turn the steering wheel to the right.. i thought maybe balljoint but its not.. any ideas?
Old Jul 5, 2006 | 07:34 AM
LowSlow93Sol's Avatar
Default Re: Del Sol Suspension Problem (majinx4)
Is it stock suspension? If not my first guess would be the tophat of the spring/shock assembly. Is the tie rod end good?
Old Jul 5, 2006 | 09:03 PM
jdeemseerx's Avatar
i had a car with the same problem the other day.. check out the boots at the end of the steering rack that cover the inner ball joints.. if they have holes in them water can get in and cause your inner tie rod joints to rust causing squeeking and grinding.. just an idea to throw out there
Old Jul 5, 2006 | 09:07 PM
FalkenSiR's Avatar
Inspect for torn boots and bushings. Look at the tie rod ends, balljoints, bushings, etc... and cv joints also.
Bad_dude
Apr 27, 2012 06:27 AM
mattbatson
Jun 25, 2008 01:25 PM
