godamn CEL
Old Jul 5, 2006 | 12:31 AM
94VXLSHatchie's Avatar
Default godamn CEL
ok so my car was throwing a bunch of CEL's... i got rid of all of them except for one... its 6(ect)... i even replaced the sensor with a new one too.. and the damn light keeps on...i disconnected my batter to see if it was throwing it from a trip mode or something and i pulled out the 15amp fuse for the ecu but nothing, its the same thing...can someone please suggest ssomething?
Old Jul 5, 2006 | 12:58 AM
Redline130's Avatar
Default Re: godamn CEL (89crxsohcvtec)
Have you checked your wiring in-between the sensor and the ecu?
Old Jul 5, 2006 | 01:06 AM
Default Re: godamn CEL (Redline130)
the wiring is unmolested to my understanding...but how would i go about to inspect it?
Old Jul 5, 2006 | 01:11 AM
Redline130's Avatar
Test each wire to the sensor for continuity between the sensor and the ecu. You will need to use a multimeter for this. This will tell you if there is a break in the wiring somewhere.
Old Jul 5, 2006 | 01:16 AM
so what if i test and it doesnt fail? what do i do next? also can this sensor affect how my car runs? becuase lately its been running shitty since the CEL
Old Jul 5, 2006 | 06:40 AM
SVOboy's Avatar
The ECT sensor greatly affects fuel trim, especially while warming up. I'd test for continuity first, then mehbe test the sensor with a DMM while the car is running to make sure it's giving good values, and then mehbe try a new ecu in case it's a random ecu issue.
Old Jul 5, 2006 | 09:46 PM
Default Re: (SVOboy)
UPDATE:
got my friend to check continuity, he said it was good, then he checked the sensor and he also said it was good...i also tried another P28 and the same CEL popped up with same code....what else can i do about it? i also noticed that my temperature gauge doesnt even go up to 1/4 ways up, so that means my motor is always cold?? can someone please shine some light on me
Old Jul 6, 2006 | 03:57 PM
Default Re: (89crxsohcvtec)
BUMP
anyone? this is driving me crazy, my car wont idle high even if its cold as its supposed to, is that related to the ECT sensor?
lmike6453
Oct 29, 2009 06:02 PM
andyt
Feb 20, 2007 06:08 PM
jlv55
Mar 2, 2004 07:30 AM
