Mini-me cam timing, help...
I've been reading on this for days, i've been reading that my timing is roughly off 7 degrees, it's a Y8 head, B1 block, single layer headgasket (.024" thinner than stock), i've read cam timing is retarded .1 degree per ~.011" and the head is retarded 4.75 degrees from the block using an 88-95 cam gear.
Since a half tooth is 4.75, a full tooth would be 9.5, shouldn't i have close to stock timing if i advance it a full tooth?
Ef4doorwagon
Mar 26, 2014 06:42 PM
d15maverick
May 3, 2004 09:14 PM
