Honda S2000 Honda S2000
Replacing OEM tires
Old Jul 4, 2006 | 08:51 PM
2camsaam's Avatar
Default Replacing OEM tires
I will be replacing my rear OEM tires this week.
Should I keep the original make and model of tires (Bridgestone Potenza)?
Also, should I keep the OEM size or should I possibly go wider w/ shorter sidewall ex: (OEM - 225/50/16 to maybe like 235/45/16)?
I am on the stock 16" wheels.
Old Jul 4, 2006 | 09:03 PM
Nishant's Avatar
Default Re: Replacing OEM tires (2camsaam)
If you stick with the OEM Potenza S02's:
Front - 205/55/16
Rear - 225/50/16
If you get another other tires besides the OEM:
Front - Same
Rear - 245/45/16
The OEM SO-2 is measure weird. It is actually equivalent to what I wrote above.
Old Jul 5, 2006 | 08:00 AM
p nut's Avatar
First, I don't think 235/45/16's exist. If they do, you'll be very limited to tire selection.
Second, to simplify what Nish was saying,
Bridgestone S02's 225 = 245 in any other tires, including other Bridgestones.
Old Jul 5, 2006 | 08:21 AM
- BSeRiouS -'s Avatar
Default Re: (P Nut)
245/45-16R
225/50-16F
if you want a wider stance.
Old Jul 5, 2006 | 09:00 AM
SilverDc2's Avatar
Default Re: (OBSeRiouso)
since the rear s-02's are 225 but really 245
are the front 205 really 215's?
if you can fit 225's in the front how much with it throw off the speedo by?
Old Jul 5, 2006 | 09:14 AM
p nut's Avatar
No, the fronts stay the same. Keep it at 205.
doctor_itr
Apr 20, 2015 05:26 AM
Fuster_Cluck
Acura TL, RL & ZDX
Apr 19, 2007 05:36 AM
hatchedeg
Honda S2000
Jan 24, 2007 09:06 PM
Declectic
Honda Civic (2006 - 2015)
10
Sep 15, 2006 05:21 AM
