Help with my dash swap PLEASE!!
Old Jul 4, 2006 | 08:41 PM
sickgsx's Avatar
Default Help with my dash swap PLEASE!!
Hey guys, I am new to the site and really need everyones imput. First of I just somewhat completed my integra dash swap in my 95 cx civic and have run into a few probloms, Does the integra dash normally sit up quite a bit higher than the stock dash??when I was putting in my shifter consol and my arm rest I noticed there really isn't any way to secure it other than to the bottom of the dash?? what did you guys do??Also when I start my car up my wipers go on and I can't turn them off. One more thing the wire that goes from the heater blower to the back of the heater control I can't get hooked up, I tried the civic one and it seems to be too short. I had modify my civic blower as I could not find one in my area,I also used the integra under dash harness. Overall everything else works great.
thanks
Old Jul 4, 2006 | 10:17 PM
lazywop's Avatar
Default Re: Help with my dash swap PLEASE!! (sickgsx)
the dash is sitting high because you are not using the integra heatercore. to get the center console to bolt in you need a integra brackets, and there is a piece of Styrofoam that goes under it to give you the right hight. I have no clue what is wrong with your wipers, but you must of made a mistake in you wireing.
Old Jul 5, 2006 | 06:19 AM
sickgsx's Avatar
Default Re: Help with my dash swap PLEASE!! (lazywop)
I trimmed the civic blower all the way down , I looked and the dash does not touch it at all. I did however use the civic dash mounts?? could that be the problom?? thanks for your help
Old Jul 5, 2006 | 09:35 PM
sickgsx's Avatar
anyone else??
Old Jul 6, 2006 | 01:12 AM
lazywop's Avatar
If you think the heater core is not affecting it it could be you have to trime more of the dash or mounts. I also used the civic dash mounts but I had to cut a piece of the mounts of on both side to make it fit right.
Old Jul 6, 2006 | 03:29 PM
sickgsx's Avatar
Thanks man for your help ^^ I didn't trim anything off the dash mounts. Everything else seems to be fine ,the integra dash I bought was already in a eg so all the trimming was already done, the only thing really left would be the mounts so I will try that.
litterbox
434
Dec 27, 2013 03:46 AM
ShankJDM
May 16, 2007 11:07 PM
Matt_2078
Oct 25, 2005 06:33 AM
AIWFCIATR
Sep 20, 2004 11:07 AM
ILOVEGIRLS
Mar 21, 2004 11:16 PM
