People that Painted their Rims- need help
Old Jul 4, 2006 | 07:05 PM
DFW's Avatar
DFW
Default People that Painted their Rims- need help
For people that painted their rims, did yall use clear coat out of a can? I don't have access to a paint gun. What kind of results will I get if I use it out of a can?
Old Jul 4, 2006 | 09:05 PM
DFW's Avatar
DFW
Default Re: People that Painted their Rims- need help (DFW)
Old Jul 4, 2006 | 09:12 PM
truegiant's Avatar
I cleared mine with a spray can and was extremely impressed. The thing with the clear for me was getting the right type of paint. I used a cheaper clear the first time and did not let it sit-up for very long and the first time I did a mtn run the brake dust embedded itself into the clear.
Old Jul 4, 2006 | 09:18 PM
DFW's Avatar
DFW
Default Re: (truegiant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by truegiant &raquo;</TD></TR><TR><TD CLASS="quote">I cleared mine with a spray can and was extremely impressed. The thing with the clear for me was getting the right type of paint. I used a cheaper clear the first time and did not let it sit-up for very long and the first time I did a mtn run the brake dust embedded itself into the clear. </TD></TR></TABLE>
Did you re-do it? How long has it been holding up?
Old Jul 4, 2006 | 09:23 PM
mike9571's Avatar
Default Re: (DFW)
Clear in a can will hold up just as good.
Old Jul 4, 2006 | 09:27 PM
mike9571's Avatar
Default Re: (mike9571)
here you go..
Old Jul 4, 2006 | 09:30 PM
shynop
Guest
Posts: n/a
clear them one time, then wait couple hours and clear again
Old Jul 4, 2006 | 09:31 PM
DFW's Avatar
DFW
Sweet thanks. i'm painting some rims that have been polished, do i just clean it, scuff it then primer, paint, clear?
Old Jul 4, 2006 | 09:35 PM
mike9571's Avatar
Default Re: (DFW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW &raquo;</TD></TR><TR><TD CLASS="quote">Sweet thanks. i'm painting some rims that have been polished, do i just clean it, scuff it then primer, paint, clear?</TD></TR></TABLE>
Yes, use the adhesive promoter too.
Old Jul 4, 2006 | 09:40 PM
DFW's Avatar
DFW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt &raquo;</TD></TR><TR><TD CLASS="quote">clean it REALLY GOOD since they have been polished
use like aircraft stripper or something, but be careful, that stuff BURNS</TD></TR></TABLE>
Yeah, got it on my fingers before
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike9571 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, use the adhesive promoter too. </TD></TR></TABLE>
What's adhesive promotor?
Old Jul 4, 2006 | 09:43 PM
mike9571's Avatar
Default Re: (DFW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, got it on my fingers before
What's adhesive promotor?</TD></TR></TABLE>
Helps whatever coating bond a little better. Make sure you use all of the same brand primer/paint, etc. They are formulated to work together.
Old Jul 4, 2006 | 09:44 PM
DFW's Avatar
DFW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike9571 &raquo;</TD></TR><TR><TD CLASS="quote">Helps whatever coating bond a little better.</TD></TR></TABLE>
Would I spray that before the paint or before the clear coat? Is it really necessary?
Old Jul 4, 2006 | 09:45 PM
mike9571's Avatar
Default Re: (DFW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW &raquo;</TD></TR><TR><TD CLASS="quote">Would I spray that before the paint or before the clear coat?</TD></TR></TABLE>
Before, also if you want you can use it before the the paint. just for a little extra adhesion.
Old Jul 4, 2006 | 09:52 PM
DFW's Avatar
DFW
How many cans you think will it take to paint all 4?
Old Jul 4, 2006 | 09:56 PM
shynop
Guest
Posts: n/a
Default Re: (DFW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW &raquo;</TD></TR><TR><TD CLASS="quote">How many cans you think will it take to paint all 4?</TD></TR></TABLE>
2, but just buy 3 just incase you od on some rims or happen to mess up, so you got a spare and don't gotta go to the store to get more, and if you fail to use the 3rd, just simply return it
Old Jul 4, 2006 | 09:57 PM
DFW's Avatar
DFW
Default Re: (shynop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shynop &raquo;</TD></TR><TR><TD CLASS="quote">2, but just buy 3 just incase you od on some rims or happen to mess up, so you got a spare and don't gotta go to the store to get more </TD></TR></TABLE>
Thanks.
As for primer would I just need one? I don't think you need a heavy coat of primer.
Old Jul 5, 2006 | 12:45 AM
ehhhdc2's Avatar
* B A N N E D *
1 can of primer is enough. i did mine couple days ago, turn out really good.
Old Jul 5, 2006 | 01:04 AM
DFW's Avatar
DFW
Default Re: (97gsr.)
Thanks. How much is a can of the Dupli-Color paint, clear and primer?
Old Jul 5, 2006 | 03:35 PM
DFW's Avatar
DFW
What grit should I scuff it with?
Old Jul 5, 2006 | 03:38 PM
ROOROWNS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW &raquo;</TD></TR><TR><TD CLASS="quote">What grit should I scuff it with? </TD></TR></TABLE>
Scuff with like 1000 or so....
that could be totally wrong for some technical reason but It worked for me.
Old Jul 5, 2006 | 04:33 PM
DFW's Avatar
DFW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BEERownsHONDA &raquo;</TD></TR><TR><TD CLASS="quote">Scuff with like 1000 or so....
that could be totally wrong for some technical reason but It worked for me. </TD></TR></TABLE>
Other ppl are saying 200?
bumppppppppppp
Old Jul 5, 2006 | 04:57 PM
4DRmafia's Avatar
i would just scuff it with 320
Old Jul 5, 2006 | 05:05 PM
Briman2021's Avatar
Default Re: (SkipMic2006)
Not to hijack, but does the clear+ adhesion promoter work well on polished wheels?? I got a set of wheels that are polished almost ot the point of looking like chrome, and I don't want to spray something on that isn't gonna stick.
Old Jul 5, 2006 | 09:14 PM
DFW's Avatar
DFW
Default Re: (Briman2021)
damn, can you spray over clear? i think i didnt spray enough base on the 2nd rim.
Old Jul 5, 2006 | 09:15 PM
spock_rocker's Avatar
memoryFAB.com representative
i was solely against clear coat.. im flat color partial!
