Lexan / Polycarbonate hatch window
Old Jul 4, 2006 | 07:02 PM
RareSI's Avatar
Default Lexan / Polycarbonate hatch window
I have a 1999 hatchback, and looking to replace the hatch with a carbon fiber unit. I was recently told that while I NEED to use a lexan / polycarbonate glass. It was expressed that the carbon fiber hatch would twist more than the OEM steel unit, thus possibly causing the glass to break.
I'd like to get to the truth on the matter. Does anyone have any real information, experience or even stories about this?
I understand that there is Lexan, which scratches easily, you need a special cleaner for it. And FAL sells polycarbonate replacements which is not quite the same as Lexan. Am I correct?
What are the side effects / cons to using a "plastic" over "glass", that is if I have that option with a carbon fiber hatch.
Thanks in advance!
Old Jul 6, 2006 | 05:42 AM
RareSI's Avatar
Default Re: Lexan / Polycarbonate hatch window (RareSI)
Anyone?
Old Jul 6, 2006 | 05:58 AM
Syndacate's Avatar
well if ur speaking of a CF tail hatch, then yeah, it's more "malable" than a metal tailgate, so it can bend and 'cause the glass to break, I've heard of htat before, never seen it though..
As for teh glass over plastic or whatever, I don't know :-\
Old Jul 6, 2006 | 07:54 AM
axtran's Avatar
you don't gain anything from making the hatch CF really - and Lexan eliminates your rear defrosters so its semi-lame all depending where you live.
Old Jul 6, 2006 | 09:03 AM
RareSI's Avatar
Default Re: (axtran)
I didn't ask for an opinion on to use carbon fiber or not. I'm not doing it to gain anything, perse.
I am adding carbon fiber to the car for visual appeal, not weight savings. I'm simply trying to find out if I absolutely need plastic or not.
Old Jul 7, 2006 | 12:34 PM
RareSI's Avatar
Anyone else?
iheartmyhatch
May 17, 2005 09:11 AM
Integra21
May 19, 2004 12:04 PM
jonyb
Nov 17, 2003 12:30 PM
jonyb
Nov 17, 2003 10:16 AM
slowinslc
28
Oct 19, 2001 01:48 PM
