OBX AEM Fuel Rail for 92-95 Civic
Old Jul 4, 2006 | 05:41 PM
Enzo Speed's Avatar
Default OBX AEM Fuel Rail for 92-95 Civic
**EDIT** IT'S A 96-00 RAIL! IT'S NOT A 92-95 RAIL.
It's an OBX rail. I bought the wrong one damnit.
I already spent 8 hours polishing it. It's not a perfect polish, I took some pics with and without the flash to give you an idea. When I realized it wouldn't fit on my car, I skipped from 600 grit to polishing compound. If you want a perfect polish, I suggest you go back and hit it with 1000 grit. Not that it's really all the noticeable once it's installed and sitting under your hood.
Also, OBX rails come with nickel-plated brass fittings. Since they are complete crap, I removed them and threw them away when I bought the rail. So you'll need a plug at one end (unless you have a fuel pressure gauge) and the inlet fitting at the other end (unless you're using braided feed lines).
And before you ask why I spent 8 hours polishing it, it's because OBX doesn't make polished rails. They come in silver with some sort of rough finish, just like AEM rails.
Anyway, shoot me an offer.
Modified by Enzo Speed at 11:56 PM 7/7/2006
Modified by Enzo Speed at 5:11 PM 7/14/2006
Old Jul 5, 2006 | 05:51 PM
Enzo Speed's Avatar
Default Re: OBX AEM Fuel Rail for 92-95 Civic (Enzo Speed)
Update: Cleaned out the garage today and found an inlet fitting . Hardened steel, not brass .
Old Jul 9, 2006 | 05:40 PM
Enzo Speed's Avatar
up
Old Jul 14, 2006 | 04:12 PM
Enzo Speed's Avatar
down
br8crumb
May 7, 2014 05:19 PM
DC2tuner
Feb 3, 2005 09:27 PM
DC2tuner
Jan 21, 2005 03:13 PM
aira
Sep 18, 2003 05:43 PM
