So do you have a miss below 3k in your car, after warmed up?
I did and I replaced every ignition part several times. I couldn't figure it out. Each time it got a little better, but then the problem came back. Turns out two years later, I was changing my clutch, and my friend pointed out my shot oem engine grounds, and I replaced them with 4ga grounds I made for my crx. Problem is gone. Car feels more powerfull, all of the time. Never boggs down either. Go replace your OEM grounds right now. Go to a stereo shop buy some 4ga, enjoy the best 20bux you can spend on a car with stock grounds.
thanks for the info. a little off topic but i had the same problem in my eclipse but the shop fixed it probably could have done it now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hyperlite1080 »</TD></TR><TR><TD CLASS="quote">Your thread made gassavers.org just thought i'd let you know.</TD></TR></TABLE>
Josh your a dork!
Josh your a dork!
