Oil Recommended for 5th Generation Accord
Old Jul 4, 2006 | 04:50 PM
fiftyOne's Avatar
Default Oil Recommended for 5th Generation Accord
Does anyone have any recommendations for which oil brand/viscosity to use in a stock 1994 f22 vtec?
Have been using Castrol Formula R 5W-30, but am finding that it is not currently available at the local autoshops. There is a Shell alternative, I can not recall the name at this moment, but it is a 5W-40 grade. Surely this should not be an issue.
So I am just wondering what oils any other owners have been using, or what people in the know would recommend.
Cheers
Old Jul 4, 2006 | 04:52 PM
immalooser's Avatar
Default Re: Oil Recommended for 5th Generation Accord (fiftyOne)
10w-30 mobil 1 synthetic
Old Jul 5, 2006 | 03:29 AM
YeuEmMaiMai's Avatar
whatever the owner's manual states or better
Old Jul 5, 2006 | 04:51 AM
Ross 2.0's Avatar
In a Junkyard near you.
Whatever the oil cap says to use (if it's the stock one)
Old Jul 5, 2006 | 10:22 AM
tyghe's Avatar
I use Castrrol syntec Blend 10/30. I have heard nothing but good things about royal purple, but it's pricey...
Old Jul 5, 2006 | 11:17 AM
jb.'s Avatar
jb.
Default Re: (tyghe)
whatever 5w30 you find will work, just change it regularly, no need for pricey oils
Old Jul 5, 2006 | 11:39 AM
defaced8's Avatar
Default Re: (jb.)
I use Valvoline 5w-30 in my 97 which has the 2.7L v6.
Old Jul 5, 2006 | 01:57 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
Default Re: (tyghe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyghe &raquo;</TD></TR><TR><TD CLASS="quote">I use Castrrol syntec Blend 10/30.</TD></TR></TABLE>
ditto for me...althought the ***** almost 4 bucks a quart
Old Jul 5, 2006 | 02:40 PM
ramoneguru's Avatar
5W-30 F22b2 with 127k and oil changes every 5,000 miles.............haven't had a serious enginge problem. Of course my front/rear motor mounts have seen better days and the "power" windows are slow as hell.................nevertheless, no serious engine problems w/ 5W-30.
Old Jul 5, 2006 | 04:47 PM
fiftyOne's Avatar
Default Re: (ramoneguru)
I know what you mean about the slow power windows, Ramoneguru.
Thanks for all of your comments. Seems that I'll stick to 5W-30.
Old Jul 5, 2006 | 04:56 PM
ck123's Avatar
squirt windex down the sides of the windows, then roll your windows up and down a few times THEN squirt the sides again with HOT water and roll the windows up and down again. This should clena up all the dirt and allow your windows to roll up and down quickly. Ive tried it on my 88 civic and it works
Old Jul 5, 2006 | 06:36 PM
gianinline's Avatar
You should consider how often and how much do you drive. What is the average temperature of when you are driving, conditions and etc.
Some of the oil gallons will have a little chart indicating what should suit you best depending on these conditions.
Old Jul 5, 2006 | 09:45 PM
95lxcoupe's Avatar
Default Re: Oil Recommended for 5th Generation Accord (gianinline)
i switched over to valvoline max-life in my dd accord, as its at nearly 120xxx, and this needs to last another 5 years.
Old Jul 10, 2006 | 09:11 PM
businessmanph's Avatar
Default Re: Oil Recommended for 5th Generation Accord (95lxcoupe)
castrol gtx and pure one purolator oil filter change every 3k
Old Jul 10, 2006 | 09:34 PM
There are many people who use regular dino oil and their cars lask 300K or more........
quickster
Apr 26, 2011 04:12 PM
djdownfawl
Honda Civic (2001 - 2005)
40
Apr 3, 2008 05:41 PM
f22b2guy
Nov 23, 2007 01:24 PM
NeriVTEC
Dec 22, 2005 01:55 PM
BoBo Racing
Honda S2000
Aug 24, 2003 07:03 PM
