Parts for Sale - Tranny, Cams, Dizzy, Fittings, Turbo parts, etc ...
Trying to clean up the garage some and have lots of parts laying around. Make offers on anything because some of it I have no idea what its worth anymore. PAYPAL accepted here.
FUEL FILTER FEED ADAPTOR - This is something I made, its for connecting your STOCK fuel feed line (after removing the fuel filter) to an aftermarket filter or anything else. It's a -6AN fitting. $20 shipped/paypaled
STARTER FOR B-SERIES - $45 each shipped/paypaled obo
TOP CAMSHAFT - GSR INTAKE CAM, BOTTOM CAMSHAFT - B16 INTAKE CAM - $30 each shipped/paypaled
94-97 INTEGRA TAIL LIGHTS IN GREAT SHAPE - $80 shipped/paypaled obo
OBD0 (PRE-OBD) DISTRIBUTOR IN GREAT SHAPE - $35 shipped/paypaled obo
1-5/8 FLEX HONE - $18 shipped/paypaled
BOSCH PLATINUM 4227'S 6 HEAT RANGE FOR B-SERIES - make offer
5-BOLT TURBONETICS T3 EXHAUST HOUSING UNKNOWN SIZE - SOLD
B-SERIES EQUAL-LENGTH MANIFOLD - NEED WG AND TURBO FLANGE AND INNER COLLECTOR COMPLETED - $SOLD
PIAA ULTRA BRIGHT FOG LIGHTS W/EXTRA NEW BULB AND ONE ALREADY REPLACED (BASICALLY TWO NEW BULBS), MISSING 1 BRAKET, IN GOOD SHAPE WITH COMPLETE HARNESS - $80 shipped/paypaled obo
SUPER SEQUENTIAL EXTRA TIP - $15 shipped/paypaled obo
APC FIRE EXTINGUISHER, NEVER USED, GREAT SHAPE - $30 shipped/paypaled
2 TAPER DIFFERENTIAL BEARINGS USED IN ITR TRANNY'S AND OTHER - $50 shipped/paypaled for both
QTP QTEC E-CUTOUT 3" MISSING BUTERFLY PLATE AND HARNESS - $70 shipped/paypaled obo You can get these from QTP for free or for a small charge. I had the parts I just cannot find them.
MISC. COUPLINGS - Make offer
ITR OIL PUMP USED VERY BREIFLY FOR OIL PRESSURE TEST - $75 Shipped/paypaled
USED EAGLE RODS W/ 5/16" BOLTS - 3 of 4 rods are in great shape. One rod had an overheated NOT SPUN bearing in it and thus the rod has a hot spot seen in the pictures. I was going to keep these for a budget build but I'll never get around to it. Great for someone wanting to save some money and throw together a play-motor. $SOLD
ENDYN 84.5MM PISTONS WITH HEAT DAMAGE TO ONE SIDE. I dont know if these are worth anything but if you want them shoot me an offer. The skirts are the only part that show anything was wrong. The tops are untouched.
EBAY SHORT SHIFTER FOR DC INTEGRA, DUNNO WHO MAKES IT - $20 shipped / paypaled
38MM TIAL FLANGES (2), AND 3" - 3BOLT FLANGES 940, AND 4 BOLT TURBO FLANGE FOR SOME WEIRD TURBO CONFIGURATION - Make offer
FROM LEFT TO RIGHT
-STAINLESS -10AN 45DEGREE SWIVEL FITTING,
-4AN BRAIDED HOSE FOR VTEC,
-OIL DRAIN FITTING AND RUBBER GASKET,
-4AN TO REAR OF CYLINDER HEAD FOR VTEC CONVERSION,
-TWO -12AN ALUMINUM WELD-ON FITTINGS SOLD
-ON TOP IS -10AN HOSE END AND FITTING FOR OIL PAN OIL RETURN.
MAKE OFFER
5-WIRE LEAN-BURN O2 SENSOR (I THINK) make offer
virgin P75 ECU $75 shipped / paypaled
virgin P28 ECU mistake
OEM LS CRANK - has been polished but machinist said is out of round by a few thousanths. $60 shipped / paypaled
LS TRANNY - needs new input shaft bearing and 3rd gear syncro SOMETIMES acts up. The DIFF has been replaced once before and is OEM now. Currently disassembled, will ship as such or some form of partial assembly due to needing ISB. $SOLD
Modified by stizzit at 6:28 AM 7/6/2006
Modified by stizzit at 5:53 PM 7/6/2006
Modified by stizzit at 6:27 PM 7/6/2006
Modified by stizzit at 1:46 PM 7/9/2006
Modified by stizzit at 9:21 PM 7/12/2006
Modified by stizzit at 12:36 PM 8/5/2006
FROM LEFT TO RIGHT
MAKE OFFER
I MAT NEED THE ALTERNATOR FOR MY B20 ILL TRY TO K.I.T OR E-MAIL ME AT BROTHERKUSH@HOTMAIL.COM THX MAN
