trans. issue
Old Jul 4, 2006 | 02:01 PM
ajth87's Avatar
Default trans. issue
i have a transmission prob that i need help with. I have a 91 accord lx and sometimes when I take my car out of drive to a different gear it is real hard to take out of park and sometimes it is hard to put back in park. the gears shift hard too, any ideas please help. o0o and another thing. how can i fix my taillights,brakelights. only my left driver side brake light works but the back window brake light and right brake light dont work. when the lights are on they light up but when the breaks are pushed they dont. if i mess with the wires it works but then goes out. any ideas. thanks
Old Jul 4, 2006 | 02:42 PM
YeuEmMaiMai's Avatar
Default Re: trans. issue (ajth87)
auto i guess?
Safety interlock is first thing I would look at.
Change trans fluid and add a can of lube guard for imports
Old Jul 4, 2006 | 07:25 PM
zx9rbart's Avatar
Default Re: trans. issue (YeuEmMaiMai)
i had the exact same lighting problem...found corrosion in the harness plug behind the panel for the right rear brake light. Disconnect the plug...clean and sand the pins and squirt some deox in there...
Nonio
May 8, 2014 05:39 AM
'Accord Ex'
Jan 23, 2007 07:18 PM
dynamo
Jan 11, 2007 11:27 AM
Drew408
Mar 30, 2003 07:42 PM
D-Day
May 23, 2001 06:31 PM
