Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
brake pedal freeplay
Old Jul 4, 2006 | 11:06 AM
nscirocco's Avatar
Default brake pedal freeplay
i installed a new master cylinder. i adjusting the free play to have less than 5mm. I was able to bed the new pads in without problems.
i went on the track and after 5mins the pads started locking up, i managed to get to the pits where they locked up hard .. then the pads caught fire (i guess they didn't like the lack of air from stopping).
i loosened the adjuster to have over 1/4" of free play and was able to do a full 20min session while using the brakes hard and didn't have any problems but the pedal feel/height isn't as good.
i have a race on saturday, so i'll probably leave it loose till after then .. but is there a trick to adjusting this? i don't have the special tool they show in the helms. I was adjusting it with the engine off, otherwise i couldn't feel the freeplay properly with my hand on the pedal... should i be doing it with vaccum in the booster?
-nigel.
Old Jul 5, 2006 | 12:20 PM
chrisw85's Avatar
are you adjusting the pushrod to m/c piston clearence or the brake pedal height on the inside of the car?
Old Jul 5, 2006 | 12:26 PM
Andrie Hartanto's Avatar
Make sure when you are adjusting it the engine is running so you have the booster working properly.
Old Jul 5, 2006 | 12:37 PM
nscirocco's Avatar
Default Re: (chrisw85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 &raquo;</TD></TR><TR><TD CLASS="quote">are you adjusting the pushrod to m/c piston clearence or the brake pedal height on the inside of the car?</TD></TR></TABLE>
both .. pushrod clearance for the free play and pedal height to help heel-toe
pedal height isn't a problem since it doesn't affect the master, it's pushrod clearance i'm having trouble with
-nigel.
Old Jul 5, 2006 | 12:40 PM
nscirocco's Avatar
Default Re: (Andrie Hartanto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrie Hartanto &raquo;</TD></TR><TR><TD CLASS="quote">Make sure when you are adjusting it the engine is running so you have the booster working properly.</TD></TR></TABLE>
i can't really feel the freeplay with the car running though .. i tried with a small vaccum pump and it's the same. it's hard to tell when free play ends and the master starts to move because of the vaccum assistance.
i cut an old master in half to try to make a botch version of the honda adjustment tool .. just won't have time to try it this week
-nigel.
Old Jul 5, 2006 | 01:10 PM
Ron Carroll's Avatar
Default Re: (nscirocco)
You will not be able to get adjustment on the push rod right with out the tool, I recommend that you take it by a shop that has the tool and pay them to adjust it. This will save you a lot of money and hassle in the long run.
Kennyjai
Nov 28, 2012 12:00 PM
EKwreckRLS
Suspension & Brakes
Aug 3, 2012 02:23 PM
pimpdd101
Nov 29, 2008 09:08 PM
drewski101
10
Aug 17, 2008 06:21 AM
djay86
16
Sep 20, 2002 11:53 AM
