how to find the 02 sensor at the cat?
Old Jul 4, 2006 | 08:36 AM
burakol's Avatar
Default how to find the 02 sensor at the cat?
im going to need to replace my 02 sensor for both the front and the one near the cat... i tried looking at it this morning but i couldnt find the 02 sensor that is supposed to be near the cat... any info on this on how to see it? pics will surely help!
Old Jul 4, 2006 | 08:37 AM
Ross 2.0's Avatar
In a Junkyard near you.
What year and model?
Old Jul 4, 2006 | 08:39 AM
standbackimapro's Avatar
How can you not find it?
Look for a Device with a wire sticking out of your exhaust somewhere
Old Jul 4, 2006 | 12:40 PM
burakol's Avatar
for a 96 accord lx... i cannot find that "somewhere"... should it be bolted on the cat itself or before/after the cat?
Old Jul 4, 2006 | 12:48 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: (burakol)
It is right before the cat.
You don't even have to jack up the car to see it. Get a flashlight, and knell down in front of the front driver's side wheel and look. You should see it.
Old Jul 4, 2006 | 12:52 PM
kluckerz's Avatar
you have to take off the catalytic to get to it
Old Jul 4, 2006 | 12:55 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: (kluckerz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kluckerz &raquo;</TD></TR><TR><TD CLASS="quote">you have to take off the catalytic to get to it</TD></TR></TABLE>
You don't have to take off the cat.
You just need to disconnect the electrical connector, and use a wrench or a O2 sensor socket wrench.
Old Jul 4, 2006 | 02:19 PM
burakol's Avatar
ok i will take a look at it again... any of you guys had expereince using the denso universal O2 sensor?
Old Jul 4, 2006 | 02:40 PM
YeuEmMaiMai's Avatar
since '96 cars are definately OBD2, there should be 1 sensor behind the cat to monitor efficiency....not sure though....
Old Jul 4, 2006 | 04:07 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: (YeuEmMaiMai)
On yeah, forgot about the 96 being OBD2. I beleive the secondary O2 sensor is located halfway in the cat. You probably will have to jack it up to see.
Old Jul 4, 2006 | 07:59 PM
burakol's Avatar
so should i take out the cat? the fron one is obvious and i can easily unbolt it... the one that is located on the cat is my problem... so should i take the cat out before i can get the sensor?
Old Jul 4, 2006 | 08:30 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
There should no need to take out the cat. That's more trouble than it's worth.
The manual shows to just disconnect the connector, and use a tool such as an oxygen sensor socket to remove it.
It should be on the cat, at an angle up towards the car.
Old Jul 5, 2006 | 11:23 AM
burakol's Avatar
i tried going under the car... looked but with no luck... should it be dirctlu bolted on the CAT itself or on the pipe before/after the CAT? im hoping that its just as easy as the one on the exh.manifold... right now my car is jacked up.. once i get a new tire, ill use a ramp to raise it up...
btw, im new to honda, esp in the accords im not so familiar with th locations, etc. of the parts... so please bear with me and any additional info for newbie is a great help!!!
Old Jul 5, 2006 | 05:01 PM
JimBlake's Avatar
It's #30.
Look on the top right side of the cat, it may be partly hidden by the heat shields.
Old Jul 5, 2006 | 05:26 PM
burakol's Avatar
do i need to take out the head sheild then? im just using an adjustable wrench to unscrew it... worked for the one at the manifold i hope itll also work for the one at the cat... i dont have the tool that moogoocow mentioned...
Old Jul 7, 2006 | 06:30 PM
JimBlake's Avatar
With the right wrench or socket, you don't have to take off the heatshield. But I bet it would be pretty difficult with an adjustable wrench.
Old Jul 7, 2006 | 08:29 PM
ayougo's Avatar
Default Re: (JimBlake)
ITS right there man.....just look harder.
tronic
Mar 14, 2011 06:45 AM
vtec.dc2
Dec 14, 2004 09:17 AM
BlueIntegraBoy
Jul 26, 2003 04:46 PM
iam7head
Sep 27, 2002 07:00 PM
