B18C - install
Old Jul 4, 2006 | 07:22 AM
superbangkok's Avatar
Default B18C - install
I am having a B18C put into my civic. Is there a way to physically identify the different B series engines. Living in Thailand, the engine is being sent to the shop tomorrow. I know this one is not a Type R but should be a standard B18C (180hp?). What should I be looking for to identify the B18C for sure, and any recommendations I should throw at the mechanics besides compression check, new clutch etc.
Old Jul 4, 2006 | 07:23 AM
JDMlyfestyle's Avatar
Default Re: B18C - install (superbangkok)
Search MAN THIS IS ASKED DAILY!!!!!!!
https://honda-tech.com/zerothread?id=983454
Old Jul 4, 2006 | 07:37 AM
Default Re: B18C - install (JDMlyfestyle)
appreciate you throwing your thread within one minute of my post, but how do you identify a B18C from a different B series?
I am not the mechanics putting this motor in and not concerned with the install details, just wanted to make sure tomorrow when the motor arrives it is in fact a B18C.
Old Jul 4, 2006 | 07:40 AM
Im not going to answer any more ?'s You can search the FAQ thread at the top of this forum.. cause u can be told the right answer and then come back with another one.. Just go through the FAQ thread and Read and read and Read so that You Learn
Old Jul 4, 2006 | 08:21 AM
hondaboy4life's Avatar
Default Re: (JDMlyfestyle)
if you look on the block of the motor, where the motor meets the transmition in the front, there is a stamp on it, a flat piece of metal that sticks out of the block a bit. It should be stamped with numbers, and it should say "b18c"
Old Jul 4, 2006 | 08:39 AM
axtran's Avatar
yes, but if the motor is from JAPAN, B18C can either mean GSR or Type-R
Old Jul 4, 2006 | 08:55 AM
eda6's Avatar
Default Re: (axtran)
my b18c has a p72 stamp on the back of the block right next to the tranny.
itr block is p73.
Old Jul 4, 2006 | 08:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axtran &raquo;</TD></TR><TR><TD CLASS="quote">yes, but if the motor is from JAPAN, B18C can either mean GSR or Type-R</TD></TR></TABLE>
Type R= Single stage manifold
GSR= Dual Stage manifold
Old Jul 4, 2006 | 08:59 AM
dohcVTECeg2's Avatar
Default Re: (eda6)
look at the intake manifold
Master23
Apr 8, 2009 04:10 AM
fcrx7zoomzoom
Jul 29, 2006 10:46 PM
NXAccordTO4B
Apr 12, 2002 07:25 PM
