What ecu do you use on a dohc zc?
My freind has a crx dx and wants a zc but we dont know what ecu to use. I searched cant find any thing. also will the tranny just mount up to the zc and engine mouts as well thats what i read but not certain. His crx is dual point injection as well. Is there a good after market suport for the zc cant find cams stuff like that.
You can use a DOHC ZC ECU and tranny. You can also use Si ECU or tranny. And there is next to nothing in the aftermarket for this motor. I would suggest swapping a SOHC VTEC or B-series motor in before a DOHC ZC. The DOHC ZC is a direct bolt in but you will have to convert the wiring harness to MPFI. Go spend some time up in the FAQ at the top of the forum it will answer your questions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad »</TD></TR><TR><TD CLASS="quote">. Go spend some time up in the FAQ at the top of the forum it will answer your questions. </TD></TR></TABLE>
The ECUs to use are the Si PM6 or DOHC ZC PG7.
You'll find plenty of parts you need, if you know where to look; not as much as the"reg. D and B series, but enough to have a good selection.
You mentioned cams, so check out http://www.exospeed.com and http://www.jgenginedynamics.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autoworks »</TD></TR><TR><TD CLASS="quote">The ECUs to use are the Si PM6 or DOHC ZC PG7.</TD></TR></TABLE>
The ECUs to use are the Si PM6 or DOHC ZC PM7.
^correct the PG7 is for the 88-89 Integra but works perfectly fine on the ZC just like the PM6 does (mount holes are different). slap my own hand on the typo
