FS: USDM H22A1 Long Block Complete. Needs Rebuild! CHEAP!
Old Jul 3, 2006 | 08:56 PM
y0whuddupb's Avatar
Default FS: USDM H22A1 Long Block Complete. Needs Rebuild! CHEAP!
well im selling my H22A1 long block which came off my prelude. its a 1993 motor. it ran really strong and healthy before i took it out. only reason why i took it off was becuz the crankshaft seal or (front main seal) took a dump on me. so i was leaking oil like krazy. i was hoping to save up enough money to rebuild the motor but i dont have time. i bought a JDM H22 cuz i didnt have time to rebuild this one. it does have 200k on the motor. the motor does have severe oil leaks. mainly coming from the front and rear main seal. and the cam seal. no cracks on the block or head. the head might a bent valve. not quite sure which one. but was misfiring a bit. i never got the chance to check it out but thats what i think it is. also, the block i never got to check out. cylinder walls should be ok. it ran strong. never got to do a compression test. but overall...this motor does need a rebuild. good for stock rebuild or racing rebuild. i'd assume all the motor needs is a full seal and gasket kit. found on ebay for like $130. it gives you all the seals and gasket you need from head to block. if you just wanna drive it. all would need replacing would be the crankshaft seal which cost $9 dollars at honda. once that is fix. it will be koo to drive but oil leaks though. i get free oil at work so thats why it really never bothered me cuz all the leaks was small. but the crankshaft seal leaked out 2 quarts in less then 1 minute. so yea thats all you would need to run it in ok condition.
the motor does come nearly complete.
it will come with the following:
head:
everything but the TB.spark plugs and wires.
block:
everything but timing cover and oil filter mount where you screw the oil filter on. but you can have my mobil 1 oil filter for free! has less than 500 miles on it.
for those who are serious interested i can get you pics tomorrow morning.
MAKE OFFER PEOPLE!! please dont throw me a retarded offer. thank you!!!
Old Jul 4, 2006 | 08:44 AM
y0whuddupb's Avatar
Default Re: FS: USDM H22A1 Long Block Complete. Needs Rebuild! CHEAP! (yO_wHuDdUp_B)
bump
ohsnapzafingcu
13
Apr 10, 2011 06:52 PM
TypeR II
Oct 12, 2006 11:25 AM
y0whuddupb
Northern California (Sales)
Jul 7, 2006 02:05 PM
y0whuddupb
Jul 5, 2006 10:49 PM
R-Toyz.com
Oct 10, 2005 03:32 PM
