is it worth buying a "new" head for a 92 civic
Old Jul 3, 2006 | 08:29 PM
drift_n_shift's Avatar
From: Off the Florida Keys, in a place called Kokomo, USA
Default is it worth buying a "new" head for a 92 civic
hey
my car has 330,000 kms on it. its a 92 si hatch. the car is blowing a bit of white smoke, so i think its time to do the headgasket. i found a completely refinished D16z6 head for around $150 cdn. is it worth changing the head too? or because of the 330,000 kms on the block, its not worth it...
any help appreciated, thanks
Modified by drift_n_shift at 10:01 PM 7/3/2006
Old Jul 3, 2006 | 08:46 PM
FalkenSiR's Avatar
Default Re: is it worth buying a "new" head for a 92 civic (drift_n_shift)
If you are planning on keeping the engine for a while then yes. Make sure you replace the rings also. (inspect pistons for damage too)
Old Jul 3, 2006 | 09:05 PM
Default Re: is it worth buying a "new" head for a 92 civic (fast95eg8)
yea, i plan on keeping it untill i can make enogh for a swap (wont be for awhhhile). the thing is, i dont wanna change things in the block too, casue then i should just swap or rebuild...
Old Jul 3, 2006 | 09:11 PM
ddd4114's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drift_n_shift &raquo;</TD></TR><TR><TD CLASS="quote">yea, i plan on keeping it untill i can make enogh for a swap (wont be for awhhhile). the thing is, i dont wanna change things in the block too, casue then i should just swap or rebuild...</TD></TR></TABLE>
If that's the case, I recommend performing a leakdown test. See where leaks are, then decide what to do. If there's pressure in the crankcase, then a different head won't help too much. If it's just symptoms of a leaking head gasket, then replace the head.
Old Jul 3, 2006 | 10:58 PM
jackiechan's Avatar
From: riCk jAmes BitCh 415 fRisKo 2 cAstRo yAy aREa, CA, usa
just save your money and get a B or K series im sure many people can vouch for that
tunerguy0985
Sep 7, 2011 02:51 PM
tunerguy0985
Sep 7, 2011 01:16 PM
ci_v_ic
Aug 10, 2006 06:24 PM
superstockhatch
Dec 14, 2005 08:28 PM
d15z6
Jan 5, 2005 12:50 PM
