215/45/17 or 215/40/17
Old Jul 3, 2006 | 07:57 PM
budget's Avatar
Default 215/45/17 or 215/40/17
215/45/17 or 215/40/17 - whats the difference if i get a 45sidewall vs a 40sidewall? is there any performance factor at all?
Old Jul 4, 2006 | 06:42 AM
huviduc's Avatar
yeah, 40 series have no sidewall flex and they are stiff, i hated them. If you leave near shitty roads, get thicker tires
Old Jul 4, 2006 | 07:43 AM
Voyage34's Avatar
Default Re: (huviduc)
they have different outer diameters so depending on your stock tire size, one may throw off your spedometer/odo more than the other.
difference in performance due to sidewall flex between those two sizes would be pretty negligible, especially if its a street car.
Old Jul 4, 2006 | 08:29 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (Voyage34)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voyage34 &raquo;</TD></TR><TR><TD CLASS="quote">they have different outer diameters so depending on your stock tire size, one may throw off your spedometer/odo more than the other.
difference in performance due to sidewall flex between those two sizes would be pretty negligible, especially if its a street car.</TD></TR></TABLE>
The larger tire may also rub. And it will result in slightly slower acceleration in any gear.
Stick with 205/40-17 for any Integra or pre-'01 Civic.
Unless you already have the tires, in which case they're free and you may as well use them up, then get the proper size when you need to replace them...
Old Jul 4, 2006 | 11:55 AM
budget's Avatar
Default Re: (nsxtasy)
this is on a 5th gen prelude
Old Jul 4, 2006 | 12:20 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (sackNsave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackNsave &raquo;</TD></TR><TR><TD CLASS="quote">this is on a 5th gen prelude</TD></TR></TABLE>
Then 205/45-17 is the best match. 215/45-17 is too big (2.3 percent larger diameter than stock) and might rub.
Old Jul 4, 2006 | 02:35 PM
Gonzob16's Avatar
You guys are 90% right about everything, speedo being off(not much) and what not.
But it comes down to how low your car sits. If you are slammed, you'll need to the 40 series and not the 45.
Also, it depends on how wide your wheel is, and the offset of the wheel....
On the 5th Gen prelude, what rims are those going on, stock or aftermarket, how wide is the wheel and lastly, are you lowered?
We need more details to help you out.
Taylor
Discount Tire Employe.
Old Jul 4, 2006 | 04:38 PM
budget's Avatar
Default Re: (Gonzob16)
the wheel is 7.5" wide and offset is 42mm
the car is lowered but not slammed, i dont want any extra wheel gap
Old Jul 4, 2006 | 06:29 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackNsave &raquo;</TD></TR><TR><TD CLASS="quote">the wheel is 7.5" wide and offset is 42mm
the car is lowered but not slammed, i dont want any extra wheel gap </TD></TR></TABLE>
Go with 205/45-17.
rice r0cket
15
Feb 2, 2007 05:48 PM
MNsnowdaboy
Aug 11, 2006 07:27 PM
1NasteeEp
Apr 10, 2004 08:13 AM
Doogie Howser
Jun 24, 2002 05:34 AM
SpeedMonkeyRacing
Jun 21, 2002 02:31 PM
