Radiator Fan Dead, Logical Progression?
Old Jul 3, 2006 | 07:31 PM
Doh!'s Avatar
Default Radiator Fan Dead, Logical Progression?
1991 Civic Si.. When I let my car idle for any length of time, it overheats, or almost does. As soon as I drive, it's fine. Obviously my fan isn't working, what is the logical way to test everything? Can I wire the fan directly to an circuit that's on with the ignition, or is there a better way to figure this out.... Thanks for the help
Old Jul 3, 2006 | 09:16 PM
Crx Jimmy's Avatar
Default Re: Radiator Fan Dead, Logical Progression? (Doh!)
just unplug the plug on the fan and hook up wires directly to the battery, if it turns on it works. then test the line going to the fan switch . ground it (when the car is on)if the fan turn on its just a bad fan switch
Old Jul 3, 2006 | 09:29 PM
fourthgenhatchB17's Avatar
Default Re: Radiator Fan Dead, Logical Progression? (Crx Jimmy)
It could also be the fan relay.
joelro28
Feb 22, 2014 12:43 PM
jmrec100
Sep 4, 2013 09:00 PM
Nameless Warrior
Dec 15, 2006 01:24 PM
