WTB: 99-00 Si Speedometer Gear (one on the diff)
Who is Mr Robot?
like title says, i need the gear to drive the vss, the one that goes on the diff. i chipped a few teeth on mine trying to get it off.
honda only sells the gear as part of a whole diff so that wont work
MUST BE FROM AN SI
MUST BE FROM AN SI
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb20coupe »</TD></TR><TR><TD CLASS="quote">http://hondamarketplace.com/zerothread?id=1670537</TD></TR></TABLE>
i dont need a diff, i need the speedo gear that goes on the diff...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi »</TD></TR><TR><TD CLASS="quote">i have it do you have pics?</TD></TR></TABLE>
the small gear on top
From: gravity rides everything...everything will fall, se GA/ne FL
i believe i have one spare. i will have to check...btw gsr/itr will work as well. the key to removal/install is to heat the speedo gear and it slips on/off with little to no resistance.
