About to order all of my fuel lines. Need a quick answer.
Old Jul 3, 2006 | 05:45 PM
J-Brooks's Avatar
Default About to order all of my fuel lines. Need a quick answer.
I am running a sumped tank, with a bosch fuel pump, 2 filters and a BDL fuel rail with an Aeromotive FPR.
Are the fittings that are actually threaded into these pieces supposed to be like this:
or like this:
I am assuming the first one but I am not 100% sure and I would like to order it all at the same time.
Also, if it is the first one are most of yall using fittings like these (with o-rings) or just the ones shown above with no o-ring.
Thanks.
Old Jul 3, 2006 | 06:13 PM
tepid1's Avatar
Default Re: About to order all of my fuel lines. Need a quick answer. (J-Brooks)
With my Aeromotive FPR I used the ones in the second pic.... I also used the second one on my fuel rail, but that is an AEM. For my sump I welded on a -12AN male so I can't help you there.
tepid1's Avatar
And what filters are you using?
Old Jul 3, 2006 | 06:55 PM
wantboost's Avatar
Who is Mr Robot?
the first one piectured is an npt to an adapter, the 2nd one is a bulhead fitting and the third is just an oringed fitting for where something doesnt have a taper
Old Jul 3, 2006 | 07:26 PM
cjames235's Avatar
Default Re: About to order all of my fuel lines. Need a quick answer. (wantboost)
EDIT: THIS IS J-BROOKS
Probably aeromotive filters.
I know what each of them are. But on websites, they don't specify whether they take -an fitting or not. Like the bdl says it has a 3/4'' opening but doesn't say whether eyou should should use like an -8an fitting or a 3/4'' ----> -8an (or 10an) fitting.
I am probably using a full race sump so it already has the bung welded. thats not a problem. I suppose the aeromotive uses the unions to on all there stuff so that takes care of the sump, filters, and fpr. I am assuming that the pump also uses the union.
I guess I just really need to know about the fuel rail. ANyone use a BDL/STR Fuel rail?
Old Jul 3, 2006 | 09:08 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: About to order all of my fuel lines. Need a quick answer. (cjames235)
the rails are generally npt
Old Jul 4, 2006 | 11:12 AM
J-Brooks's Avatar
Thats what I need to know. Thanks so 3/4 -->-8an it is
Old Jul 4, 2006 | 04:39 PM
b18ccivics's Avatar
-an to inch is what ever number divided by 16 so
-8an = 1/2
-3an = 3/16
-4an = 1/4
-6an = 3/8
-10an = 5/8
-12an = 3/4
-14an = 7/8
-16an = 16/16 = 1
-18an = 18/16 = 1 1/8
etc.
as for fittings ask your supplier, my aem rail is -6an i think bdl is -8an but not for sure just have seen them on cars and never installed one so i am probably wrong.
Old Jul 4, 2006 | 08:30 PM
IN VTEC's Avatar
Default Re: About to order all of my fuel lines. Need a quick answer. (b18ccivics)
-6AN thread is 9/16" x 18 and -8AN thread is 3/4" x 16
I don't really remember seeing any internal seats on most fuel rails and the Aermotive FPR's to seal on a flare.
To my knowledge, you should use AN o-ring port to AN flare adapters on fuel rails and the Aeromotive FPR's.
Fuel filters usually have male AN flare ends, but if they don't you should probably use o-ring port to AN flare adapters as well. If you can't make heads or tails of it, the give away is that o-ring adapters will have a countersunk seat for the o-ring on whatever piece you're installing a fitting on.
Old Jul 5, 2006 | 01:01 PM
dfoxengr's Avatar
the 1st and third pics you posted are dissimilar. first is an NPT thread, which is tapered to seal it. third is a metric probably thread which seals via the oring.
i think you really need to get someone to help you since you dont really know what youre doing.
Old Jul 5, 2006 | 09:51 PM
J-Brooks's Avatar
Default Re: About to order all of my fuel lines. Need a quick answer. (dfoxengr)
its cool. A simple call solved it all.
With out having products in hand, or websites listing what they need it is hard to know exactly what I am supposed to be buying. Thanks to Stan and the "suggested parts" tab @ summit I figured out everything thing I needed.
I didn't NOT know what I was doing. I was just uninformed of somethings and could find the answers. But thanks.
Old Jul 6, 2006 | 03:05 AM
dfoxengr's Avatar
yeah fittings are hard to figure out. i understand.
B_Swapped93
11
Apr 26, 2017 03:27 PM
BC_Garage
Aug 25, 2012 01:17 PM
street_ride14
Jul 26, 2009 02:10 PM
Powelly
Nov 23, 2007 09:58 AM
. o 69 o .
Apr 13, 2004 07:10 PM
