clutch problem on 98 sh
Old Jul 3, 2006 | 05:09 PM
thelonerangers's Avatar
Default clutch problem on 98 sh
i went go get into my car bout 10 mins ago and i got zero pressure on the clutch peddle. not sure if im usin the right terminology, basically i push the pedal down and it jus goes down with out any fight and i can't put the car into gear. the clutch fluid bottle to the right of the master brake fluid was empty. accordin the owners manual i put in some brake fluid but im still not getting anything. can someone help me out. this is my first 5-speed so im a bit of a noob with this.
Old Jul 3, 2006 | 05:12 PM
prelude1897's Avatar
Default Re: clutch problem on 98 sh (thelonerangers)
sounds like you need to replace your slave and master cyclinder
Old Jul 3, 2006 | 05:46 PM
Default Re: clutch problem on 98 sh (prelude1897)
i have no fluid tho, can u respond asap on how to pump fluid back into the system and if i gotta replace that **** how much is it gonna run me and how hard is it to do
Old Jul 3, 2006 | 06:06 PM
also if its any help or if it matters, i can put the car into gear while the car is completly off.
Old Jul 3, 2006 | 07:14 PM
arkosh.kovash's Avatar
* B A N N E D *
had the exact same prob on my 98. master cylinder needs replaced. i am under extended warranty so no problem, except for a tow. goodluck
Old Jul 3, 2006 | 07:54 PM
PiNoY_BB6's Avatar
its most probly your master cylinder.... but it also could be your slave cylinder...
Old Jul 3, 2006 | 07:56 PM
Default Re: clutch problem on 98 sh (PiNoY_BB6)
if it's your master cyclinder you should also change your slave cyclinder so that you know both parts are new adn you won't have to bleed the system all over again if the other fails
Old Jul 3, 2006 | 07:58 PM
PiNoY_BB6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">if it's your master cyclinder you should also change your slave cyclinder so that you know both parts are new adn you won't have to bleed the system all over again if the other fails</TD></TR></TABLE>
x2 that... better to be sure now... then to have to redo it again later on
Old Jul 3, 2006 | 08:35 PM
Rosko's Avatar
You prolly just ran out of fluid, but you cant just fill it up it needs to be bled...(sounds like you know that though)
There should be a write up though around here somewhere, but yeah better to waste $4 on some fluid than replace a bunch of stuff you dont need too.
Old Jul 3, 2006 | 09:41 PM
Default Re: clutch problem on 98 sh (Rosko)
my boss is comin over wit a bleedin kit in the mornin, if i gotta replace the master and slave cylinder what kind of money is that gonna run me
Old Jul 4, 2006 | 06:46 AM
I believe I paid around $80-$90 for both slave and master cyclinders from Auto Zone
Old Jul 4, 2006 | 07:09 AM
SnlpeR's Avatar
slaves are cheap...like 27 bucks
mine was a different story...
my hose gave out first....i had to flush out the old fluids...
then a couple weeks later my slave started to die...i think it didnt like the new fresh fluid..hahah
Old Jul 4, 2006 | 09:18 AM
Default Re: (SnlpeR)
update. boss came over and helped me bleed the line, i can get it in gear. im gonna take it down to my friends oil change shop have him change the gear fluid and clutch fluid. any recomends on gear and clutch fluid?
Old Jul 4, 2006 | 09:30 AM
Default Re: (thelonerangers)
as for tranny fluid, I'd go with Honda Manual Transmission fluid, and since you're up there, just get Honda Brake Fluid as well. You can use that stuff for the clutch also
Old Jul 4, 2006 | 11:09 AM
Default Re: (prelude1897)
how much u think both of those will cost me?
Old Jul 4, 2006 | 11:36 AM
tcontesh's Avatar
i know that this is a stupid question but when putting in a new clutch would it be a good idea to replace those parts or does the new clutch come with those parts?
slave and master
Old Jul 5, 2006 | 04:52 PM
Default Re: (tcontesh)
update.
4th of july clutch line was bled out. today i was at my friends oil change shop and flushed out and put in fresh honda manual tranny oil. thanx for all the help guys. feels great btw when i shift
Mr. Eric
Nov 18, 2008 09:30 AM
boostmee
Feb 7, 2008 04:12 AM
funtak
Nov 9, 2007 04:48 AM
tytyguy
Dec 3, 2005 02:32 AM
juniordc2
Jul 2, 2002 08:33 AM
