Removing high pressure power steering line from rack
Old Jul 3, 2006 | 04:52 PM
kornerk12's Avatar
Default Removing high pressure power steering line from rack
How did you guys do it ? I tried using a 14mm open end and im not slipping but i just cant turn it. I tried a breaker bar with a crowsfoot and theres not too much room. Any ideas ? BTW this is for looping the power steering lines.
Old Jul 3, 2006 | 06:55 PM
mgags7's Avatar
use a pipe wrench dude
Old Jul 4, 2006 | 07:44 AM
kornerk12's Avatar
Default Re: (mgags7)
Tried it but cant get enough behind it with a small wrench. If i use a big wrench then there is nowhere to move the wrench.
Old Jul 4, 2006 | 08:53 AM
98vtec's Avatar
moderator emeritus
Default Re: (kornerk12)
i just used a pair of pliars and a ratchet to take off the mount holding down the line.
Old Jul 4, 2006 | 12:01 PM
kornerk12's Avatar
Default Re: (98vtec)
I tried a pipe wrench, open end wrench, flare nut wrench, breaker bar with a crowsfoot, and also vise grips. Nothing has been able to turn it. In the manual it says to use a 14mm flare nut wrench but i cant get anything behind it. Pliers i doubt would work if vise grips are slipping. And i also sprayed it with PB blaster
Old Jul 4, 2006 | 02:42 PM
kornerk12's Avatar
bump
Old Jul 4, 2006 | 02:55 PM
577HondaPrelude's Avatar
I did it a few years ago but, I think I cut all the lines then removed the rack. After it's out the fittings are EZ to get off
Old Jul 5, 2006 | 03:17 PM
kornerk12's Avatar
Default Re: (577HondaPrelude)
I would rather not remove the rack if i can avoid it. Anyone else have any suggestions ? Because this bitch aint coming off .
Old Jul 5, 2006 | 03:40 PM
mgags7's Avatar
are you replacing the line??
if so, cut it, then get a box end over it and it will def come off.....
Old Jul 5, 2006 | 03:48 PM
kornerk12's Avatar
good idea ill try that..thanks
Old Jul 5, 2006 | 07:17 PM
kornerk12's Avatar
ok i got it....i cut the hard line and then used the box wrench to get it off. I still had to push really hard to get it off. Anyway i have everything hooked up and am getting a check engine light and ATTS light. I had to disconect one sensor that was on the high pressure line. Any ideas why i am getting this light ... ?
wtank
Jun 22, 2018 12:06 PM
inane
Apr 4, 2005 07:15 PM
justdrewit25
Apr 30, 2004 12:33 PM
