whats the difference between ITR and GSR stock cat exhaust?
Old Jul 3, 2006 | 03:19 PM
smooz EK's Avatar
Default whats the difference between ITR and GSR stock cat exhaust?
is there a difference?
Old Jul 3, 2006 | 04:05 PM
smooz EK's Avatar
if u were to replace the stock gsr cat for the itr cat exhaust, would there be a slight performance upgrade?
Old Jul 3, 2006 | 04:09 PM
teggywepower
Guest
Posts: n/a
Default Re: (smooz EK)
No theres not a differnce. I own a gsr. If u want big sound just get a full custom made cat-back. Itr is not differnt when it comes to exhaust. Well the header is, but not the exhaust part.
Old Jul 3, 2006 | 05:38 PM
smooz EK's Avatar
kool. thanks for the tip.
Old Jul 3, 2006 | 07:02 PM
Usagi Yojimbo's Avatar
From: Dont say my car is topless say the titties is out
OEM ITR
Big difference in look compared to the stock gs-r. Piping is also 2.5" instead of 2.25"
Old Jul 3, 2006 | 07:09 PM
smooz EK's Avatar
ic. so if i have cam gears and itr cam shafts and am planning to get dc or itr 4-1 headers, the itr exhaust would be a better fit since it is 2.5", correct?
Old Jul 3, 2006 | 07:24 PM
unless you want to spend the money for a more performance based exhaust, such as an rs*r or something, I'd say get the oem itr. I have one on my car and i love it.
Old Jul 3, 2006 | 09:06 PM
LsHoney84's Avatar
Default Re: (teggywepower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggywepower &raquo;</TD></TR><TR><TD CLASS="quote">No theres not a differnce. I own a gsr. If u want big sound just get a full custom made cat-back. Itr is not differnt when it comes to exhaust. Well the header is, but not the exhaust part. </TD></TR></TABLE>
Correct me if im wrong but the itr is 2.25 mandrel bent stainless steel whereas the gsr, is 1.9-2.0 crush bent mild steel.
If im correct, then you can do the calculations.
Old Jul 3, 2006 | 09:20 PM
superls92's Avatar
Default Re: (LsHoney84)
The type r mufler is better then the gsr muffler.
Old Jul 4, 2006 | 08:23 AM
96 GSR-T's Avatar
Default Re: (superls92)
The whole ITR exhaust system is different, it will make improvements over the stock GSR, not enought to blow your tires off and send you into VTAKK warp speed or anything, but its an improvement over stock.
Old Jul 4, 2006 | 08:45 AM
iH8RICERZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsHoney84 &raquo;</TD></TR><TR><TD CLASS="quote">Correct me if im wrong but the itr is 2.25 mandrel bent stainless steel whereas the gsr, is 1.9-2.0 crush bent mild steel.
If im correct, then you can do the calculations. </TD></TR></TABLE>
you are correct.....there's been quite a few threads exactly like this...I cant seem to find them right now though. Anyways, one thread showed internally how the itr muffler system flows smoother than the gsr. Also, there was another thread that showed a pic of a gsr and itr cat back system laying next to eachother. The itr catback system has smoother bends (mandrel bends), piping was slightly bigger in diameter, and on the 98+ systems, the tip is welded and slightly bigger compared to the gsr. If I find those threads, I'll link them...
performance wise, you'll probably get the same exact gains if you were to go with a rsr, apexi ws2, or greddy sp cat back system...which is maybe 2whp if that! Like some one had mentioned earlier, you probably wouldnt feel anything on the butt dyno.
Old Jul 4, 2006 | 09:24 AM
Robstunner4's Avatar
Default Re: (Usagi Yojimbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Usagi Yojimbo &raquo;</TD></TR><TR><TD CLASS="quote">OEM ITR
Big difference in look compared to the stock gs-r. Piping is also 2.5" instead of 2.25"</TD></TR></TABLE>
ITR piping is not 2.5"
Old Jul 4, 2006 | 09:57 AM
diversegsr's Avatar
Default Re: (Robstunner4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Robstunner4 &raquo;</TD></TR><TR><TD CLASS="quote">
ITR piping is not 2.5"</TD></TR></TABLE>
actually on the JDM OEM itr it is 2.5...the usdm is 2.25
Old Jul 4, 2006 | 12:48 PM
daLixz25's Avatar
I know that the JDM header collector is 2.5", but if I remember correctly, the exhaust is 2.36".
Old Jul 4, 2006 | 01:18 PM
H23 Power's Avatar
Default Re: (daLixz25)
anyone wanna sell me an ITR axle back??
Old Jul 4, 2006 | 01:20 PM
jweezy225's Avatar
Default Re: (H23 Power)
buy an RS*R lol
Old Jul 4, 2006 | 01:31 PM
Dngerzone2's Avatar
Default Re: (jweezy225)
ITR Cat back is also shorter then the GSR and if youre just using the ITR catback with the GSR cat/header then you need to make an extension. My car feels a lot smoother with the ITR catback as compared to the stock GSR
Old Jul 4, 2006 | 03:05 PM
smooz EK's Avatar
Default Re: (Dngerzone2)
i was planning on getting the itr piping and muffler and adding an itr header.
Old Jul 4, 2006 | 03:09 PM
jdm_bones's Avatar
Default Re: whats the difference between ITR and GSR stock cat exhaust? (smooz EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smooz EK &raquo;</TD></TR><TR><TD CLASS="quote">is there a difference?</TD></TR></TABLE>
one is gsr and the other itr...HAHAHAHA!
Old Jul 4, 2006 | 05:25 PM
91maroonGoon's Avatar
would this hook up to a obd0 b18a or would it not work because these systems work on a obd2 platform
Old Jul 4, 2006 | 05:45 PM
stumpyf4's Avatar
I believe you are correct with your dimensions. When I installed my ITR exhaust it looked way better than the crappy rusty GSR.
Old Jul 4, 2006 | 09:32 PM
teggywepower
Guest
Posts: n/a
Default Re: (stumpyf4)
Whats the big deal if there is a differnce. I just went to the exhaust shop told the guy I want a hi flow catconverter 2.5in piping all the way back and a 4.5 inch can all done in 304 stainless steel all under 300 bucks custom made and installed.
Old Jul 5, 2006 | 04:29 AM
jweezy225's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teggywepower &raquo;</TD></TR><TR><TD CLASS="quote">Whats the big deal if there is a differnce. I just went to the exhaust shop told the guy I want a hi flow catconverter 2.5in piping all the way back and a 4.5 inch can all done in 304 stainless steel all under 300 bucks custom made and installed. </TD></TR></TABLE>
good job
Old Jul 5, 2006 | 04:35 AM
96 GSR-T's Avatar
Damn thats cheap, I just paid almost $700 for 4" 304 SS piping and all the associated bends and a muffler from burns stainless, un-welded.
Old Jul 5, 2006 | 09:33 AM
SilverDc2's Avatar
Default Re: (diversegsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diversegsr &raquo;</TD></TR><TR><TD CLASS="quote">
actually on the JDM OEM itr it is 2.5...the usdm is 2.25</TD></TR></TABLE>
catback? no, i have had a usdm cat back and usdm catback, the jdm one is longer i believe cause of the header, but the piping is the same, the muffler is a tad different, the tipe sticks out 1" more,
