Parts for my B18C swap, anything missing?
Old Apr 18, 2002 | 07:35 PM
EKen9's Avatar
Default Parts for my B18C swap, anything missing?
I'm planning on putting in my OBDI JDM B18C into my 98 EK in a couple weeks and here is a list of everything I have bought for it. Let me know if there's anything I'm missing!
-clutch
-flywheel
-Si rear tranny mount
-Si drivers mount
-motor mount inserts
-USDM OBDI p72 ecu
-OBDII to OBDI conversion harness
-muffler
-timing belt
-spark plugs
-spark plug wires
-distributor cap and rotor
-manual trans fluid
-oil and filter
-intake
-shift linkage
-coolant
I hope to get some JDM ITR 4-1's and a cat too!
Old Apr 18, 2002 | 07:38 PM
Malachi's Avatar
Default Re: Parts for my B18C swap, anything missing? (VTECivic2K)
engine and transmission help goodluck with the swap
Old Apr 18, 2002 | 08:33 PM
fowler!'s Avatar
What engine harness are you going to use? 96-98 Ex harness would be my choice.
Old Apr 19, 2002 | 05:27 AM
EKen9's Avatar
Default Re: Parts for my B18C swap, anything missing? (Malachi)
You think I really need those? I think I'll be fine without them
Old Apr 19, 2002 | 05:34 AM
EKen9's Avatar
Default Re: Parts for my B18C swap, anything missing? (fowler)
I'm having trouble finding one, also do I need an OBDI distributor??
Old Apr 19, 2002 | 06:35 AM
fowler!'s Avatar
No, the distributor's OBD has to match the OBD of the wiring harness.
So, if you have an OBD 1 motor, you're going to have to switch out the injectors and the distributor, well, unless you want to get down on some wiring..
Old Apr 19, 2002 | 05:38 PM
PrecisionH23a's Avatar
you are definetly going to need a type r sticker. it will add 15 hp
710dabber
Feb 22, 2015 09:05 AM
smiko0124
May 20, 2010 08:06 AM
sk8board{Pete}
25
Oct 2, 2007 10:06 PM
jadsi420
May 10, 2006 05:43 AM
clncivic
May 15, 2002 06:50 AM
