help turn signal not working???
i change my front dash so i took out everything from the airbag to the gauge cluster and the turn signal but it didn't work after i put everything back on. could it be a fuse???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by choua01 »</TD></TR><TR><TD CLASS="quote">fuse can cause turn signal to go out right?? where is the fuse for the turn signal located at?</TD></TR></TABLE>
Isn't it in the fuse box located on the lower let hand side of the steering column?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18B-SC »</TD></TR><TR><TD CLASS="quote">did you check your blinker fluid?
haha jp
Dont forget to change the filter
haha jp
</TD></TR></TABLE>Dont forget to change the filter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by choua01 »</TD></TR><TR><TD CLASS="quote">"Teh blinker fluid is in the blinker, unscrew the cap and fill"
the blinker still turns on if i press the hazard light so i think its a electrical promblem.</TD></TR></TABLE>
I am sure it is, guess teh blinker fluid is ok then
check the fuse box under the hood of the car.
problem solved!!!! thank you for all your help guys..
the problem was that the hazard switch, when you push it in it suppose to stay there rigth? well mine isn't so i replace it and the signal lights automatically works.
