Gsr rear sway bar on EG
Old Jul 3, 2006 | 09:43 AM
Super Trooper's Avatar
Default Gsr rear sway bar on EG
I currently have no sways on my eg. Would a rear sway bar off a gsr make a huge difference in handling? I, also thought of just installing a Megan R/L tie bar that i have laying around. Which should I install.
Modified by Super Trooper at 2:11 PM 7/3/2006
Old Jul 3, 2006 | 10:51 AM
cyb3rjak's Avatar
Default Re: Gsr rear sway bar on EG (Super Trooper)
huge no, good admout of difference yes
Old Jul 3, 2006 | 12:28 PM
JSPECSIR's Avatar
Default Re: Gsr rear sway bar on EG (cyb3rjak)
make sure you get the integra rear lca's also , as the eg will not have the holes to mount the gsr bar in. but yes there is a noticable difference, i got the whole sway bar and lca setup from a local salvage yard for $100. if you have ?s on install im me.
Old Jul 3, 2006 | 12:43 PM
-Gary-'s Avatar
Default Re: Gsr rear sway bar on EG (JSPECSIR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECSIR &raquo;</TD></TR><TR><TD CLASS="quote">make sure you get the integra rear lca's also , as the eg will not have the holes to mount the gsr bar in. but yes there is a noticable difference, i got the whole sway bar and lca setup from a local salvage yard for $100. if you have ?s on install im me. </TD></TR></TABLE>
Funny how in two posts you can get someone who doesn't know what they are doing and wo does.
Old Jul 3, 2006 | 01:46 PM
prison_snitch's Avatar
yea it does. make shure you get integra LCAS or omni LCAs for 100 bucks. i got a gsr sway bar for free from my friend it does make a different. but i also got neuspeed strut bar and lower tie bar and suspension. my car has almost zero body roll
Old Jul 3, 2006 | 03:00 PM
JSPECSIR's Avatar
Default Re: Gsr rear sway bar on EG (scuzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scuzz &raquo;</TD></TR><TR><TD CLASS="quote">
Funny how in two posts you can get someone who doesn't know what they are doing and wo does.</TD></TR></TABLE>
what the hell is that supposed to mean?
Old Jul 4, 2006 | 06:12 PM
JSPECSIR's Avatar
heres a pic of mine. only pic I got but it was taken to show exhaust clearance. oh and for the people that dont like it red get over it.
Old Jul 4, 2006 | 06:17 PM
JSPECSIR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECSIR &raquo;</TD></TR><TR><TD CLASS="quote">make sure you get the integra rear lca's also , as the eg will not have the holes to mount the gsr bar in. but yes there is a noticable difference, i got the whole sway bar and lca setup from a local salvage yard for $100. if you have ?s on install im me. </TD></TR></TABLE> and as for this I ment the lca's dont have the holes. the chassis however does.
Old Jul 4, 2006 | 06:21 PM
byronl's Avatar
i just recently bought a gsr rear sway bar with omni power control arms too. I can't wait to install em as soon as they come in. I'm also gonna get new energy suspension rear sway bar bushings, u should look into that as well.
Old Jul 4, 2006 | 07:13 PM
Thanks for all the help guys.
Old Jul 4, 2006 | 08:46 PM
oh i forgot you need 4 bolts and nuts cuz EG subframes dont have welded nuts.. you gotta put the bolt from the inside and hold it there while you put the nut on.. here's a tip: use a wrench with a peice of tape on \one side to hold the bolt
Old Jul 4, 2006 | 08:49 PM
potatostix's Avatar
I just installed one last night. GSR rear swaybar, energy suspension polyurethane bushings. Used grade 8 hardware from ace, and already had omnipower contorl arms. It was a noticeable difference and I think it was a great mod for only costing me around 50$ when it was all said and done.
JDMCRX
Suspension & Brakes
Jul 10, 2009 11:04 AM
Paul-eg
Aug 29, 2008 04:33 PM
E36 Guy
Nov 2, 2005 06:55 PM
carsaregood
13
Nov 22, 2004 10:31 PM
phantom_sol
Oct 14, 2003 09:13 AM
