cometic headgasket thickness .72'' too thick for b16a
Old Jul 3, 2006 | 04:35 AM
b18sihatch's Avatar
Default cometic headgasket thickness .72'' too thick for b16a
i have a stock b16a and im boosting ti and looking to drop the compression in the motor some for detonation and other reasons. is .72'' thickness too thick or just right?
as you know the b16acompression is 10:4:1 im not looking to run a huge ammount of boost maybe 8-10psi.
also im looking to replace some bolts, do you think that replacing the rod bolts,main bolts and headstuds with arp is worth the money ?
Old Jul 3, 2006 | 08:31 AM
b16hybridsol's Avatar
Default Re: cometic headgasket thickness .72'' too thick for b16a (b18sihatch)
do you mean .072
Old Jul 3, 2006 | 09:09 AM
pgmatt's Avatar
Default Re: cometic headgasket thickness .72'' too thick for b16a (b16hybridsol)
That should put you around 9.2/9.3:1 compression and yes some ARP headstuds while its apart are a good investment.
Old Jul 3, 2006 | 09:12 AM
b18sihatch's Avatar
Default Re: cometic headgasket thickness .72'' too thick for b16a (pgmatt)
yea i meant .072'' is that the thickest u can go? or is trhere bigger? if theres thicker does anyone have a link to larger ive looked and found .072 i seen one on ebay that was .078''
Old Jul 3, 2006 | 07:40 PM
90 JDM EF8's Avatar
just got my .051" thick from cometic... it should drop my b16b to 9.6:1...will let you know how it is when i get it running in a few weeks...
goldegg
Nov 11, 2006 09:06 AM
1PT-SICK
Apr 15, 2006 03:22 PM
sikcrx80
Jan 8, 2004 04:46 PM
slooowDX
Jan 19, 2003 08:29 PM
