Why Do I Get Short Gears On H23?
Old Jul 2, 2006 | 11:54 PM
95Civic_H23's Avatar
Default Why Do I Get Short Gears On H23?
Please help me people...ANYBODY???Here's the problem.I have A 95 Hatch Swapped H23a1...I dont know why but for some reason i always get short gears...It basically happens to all gears except 2nd gear...And it only hits up to 6000 rpm..Thats the redline for my motor...I know it was suppose to get up to 6500 rpm for a h23 prelude...please help me anyone...anybody....
Old Jul 3, 2006 | 02:34 AM
darkspector's Avatar
what the hell does short gears mean?
Old Jul 3, 2006 | 05:24 AM
Eddiebx's Avatar
height challenged?
Old Jul 3, 2006 | 06:34 AM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
Default Re: Why Do I Get Short Gears On H23? (95Civic_H23)
WTH are you meaning by short gears??????? yes a H23 has shorter gears than a F22 tranny but I'm not thinking this is what your meaning?
Old Jul 3, 2006 | 09:37 AM
AndyD's Avatar
I am guessing he means he can't rev all the gears out to redline.
Why would you want to rev the H23 that high anyway? You are just buzzing the engine and ruining it.
Old Jul 3, 2006 | 11:14 AM
Finest's Avatar
Okay, first of all it's not your transmission. It's your ECU. The H23a transmission is fine, I've taken my Lude Si up to 7500 before.
But back to the question: What ECU are you running?
Old Jul 3, 2006 | 11:19 AM
94Vtecluder's Avatar
Default Re: Why Do I Get Short Gears On H23? (Finest)
Check your oil level too.
Old Jul 4, 2006 | 11:14 AM
InvaderTrax's Avatar
Default Re: Why Do I Get Short Gears On H23? (94Vtecluder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Vtecluder &raquo;</TD></TR><TR><TD CLASS="quote">Check your oil level too.</TD></TR></TABLE>
H22 - Low oil = no VTEC = lower rev limit
H23 - Never had VTEC = doesn't care about oil unless there's none at all = oil light
Does your check engine light come on?
Old Jul 4, 2006 | 09:35 PM
petern101's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest &raquo;</TD></TR><TR><TD CLASS="quote">Okay, first of all it's not your transmission. It's your ECU. The H23a transmission is fine, I've taken my Lude Si up to 7500 before.
But back to the question: What ECU are you running? </TD></TR></TABLE>
right..........seeing as a h23 loses power at around 5700ish rpm.
and the fact the stock tach is really off at that high. you don't need to rev your h23 that high nor will it benefit you in anyway.
Old Jul 5, 2006 | 09:58 AM
Finest's Avatar
Default Re: Why Do I Get Short Gears On H23? (petern101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petern101 &raquo;</TD></TR><TR><TD CLASS="quote">
1) Aftermarket Tach and also Datalogged.
2) Crower Stg 2 cams, valvetrain.
3) Turbo.
Any other questions?
Old Jul 5, 2006 | 12:09 PM
petern101's Avatar
3) Turbo.
Any other questions? </TD></TR></TABLE>
yeah why aren't you using a f22 tranny?
Old Jul 5, 2006 | 12:53 PM
Finest's Avatar
yeah why aren't you using a f22 tranny?</TD></TR></TABLE>
If it ain't broke, don't fix it. (Original transmission, with a 6 puck clutch) Gearing is fine, I top out 4th gear @ 7500 through the traps on 26" slicks.
Old Jul 5, 2006 | 01:50 PM
petern101's Avatar
ahhh i c.
well in your case, then yes i would keep the h23 tranny
crownsk8er
Dec 6, 2006 03:50 PM
farhan445
Nov 24, 2006 02:51 PM
stpierredm
Jun 18, 2006 12:50 PM
EsQueue
Jul 25, 2004 11:40 AM
