00 Si shutting off while driving
Old Jul 2, 2006 | 09:01 PM
96Civic_Coupe's Avatar
Default 00 Si shutting off while driving
my buddy test drove an EBP 00 Si today, it was stock except for a CAI.
i ran really smooth but i shut off a couple times during the test drive, one time we were cruising on the highway and it shut off, so its not like he stalled it or anything....
what would make the car do this?
i mean it really drove smooth, except when it would shut off
Old Jul 2, 2006 | 09:09 PM
siblues's Avatar
Default Re: 00 Si shutting off while driving (96Civic_Coupe)
I am having the same problem with mine and I am thinking it might be the coil but i am not sure?Bump for more answers
Old Jul 2, 2006 | 09:12 PM
potatostix's Avatar
Check your anti theft system, took forever to find the problem on a friends car. After replacing relays and weeks of issues it ended up being a loose connection in the steering column causing the car to die
Old Jul 2, 2006 | 09:32 PM
E46Kid's Avatar
Default Re: (potatostix)
probably is the dizzy, mine fucked up and i had to replace it
Old Jul 2, 2006 | 11:12 PM
Rev2Eight's Avatar
Alright i believe there is a recall on this issue that i read somewhere. If thats the case then you could bring it to the dealer and theyll replace the ignition free of charge. http://www.automotive.com/2000....html
Old Jul 3, 2006 | 01:07 AM
jdmrwd's Avatar
is the battery loose?same problem that happened to my car
Old Jul 3, 2006 | 06:14 AM
bluevic99's Avatar
Does it stutter and then die or just dies? Also thowing any codes?
Simmerman
Appearance Build Threads
64
Apr 1, 2008 06:02 PM
AutoXsi2000
Mar 8, 2002 09:27 AM
