clutch issues HELP
ok i have a h22 swap in my 94 accord. about 3 months ago i put a exedy 3 puk clutch in it. then i had to put a clutch master cyl in it. it works great on low rpm then around 5500 rpms the clutch pedal seems to fade and it gets worse as the rpms get higher. i can't speed shift at all due to this but as long as i keep the rpms low enough to where i have a clutch pedal it shift great. anyone know what could cause this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">define: fade?</TD></TR></TABLE>
Definitions of fade on the Web:
* become less clearly visible or distinguishable; disappear gradually or seemingly; "The scene begins to fade"; "The tree trunks are melting into the forest at dusk"
* lose freshness, vigor, or vitality; "Her bloom was fading"
* slice: a golf shot that curves to the right for a right-handed golfer; "he took lessons to cure his slicing"
* evanesce: disappear gradually; "The pain eventually passed off"
* languish: become feeble; "The prisoner has be languishing for years in the dungeon"
* gradually ceasing to be visible
as opposed to tight compact shifts its softer and more spongey almost
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by londonsupra »</TD></TR><TR><TD CLASS="quote">Definitions of fade on the Web:
as opposed to tight compact shifts its softer and more spongey almost</TD></TR></TABLE>
okay jackass, I know what the literary definition is. I'm asking him what HE means by the word.
bucknuts
Apr 5, 2005 04:27 PM
