RockFord Fosgate P5002
Hey everyone. am selling my Rockford Fosgate Amp P5002 (2Channel).i had my 2 12" Rockford RFD2212 to them and hits hard as ever.Only had it in my car for about a Month or two had it customed in my trunk.Took it out over a month ago but am puting Kicker in my trunk so am going to get rid of it. I only had it in the car for about a Month so its just about new almost new. am looking for $150 or someone give me an Offer.
Pic 1
http://www.cb7tuner.com/vbb/at...=3673
Pic 2
http://www.cb7tuner.com/vbb/at...=3674
Pic 3
http://www.cb7tuner.com/vbb/at...=3675
Looking for $150 B/O In Oringal Box and Amp papers
(with Shipping and Insurance)
Will do Pay Pal
Email me at Prtonyrican@aol.com if any Question or my AIM at Prtonyrican
Type Component
Amplifier Type Dual Channel
RMS Power at 4 ohms (Watts x Channels) 125 x 2
RMS Power at 2 ohms (Watts x Channels) 250 x 2
Bridged RMS Power (Watts x Channels) 500 x 1
Peak Power Output (Watts x Channels) 750 x 2
Built in Crossover Yes
Low Pass Crossover 40 - 400 Hz
High Pass Crossover 40 - 400 Hz
Low-Pass Slope (dB/octave) 12 dB
High-Pass Slope (dB/octave) 12 dB
Bass Boost 0 - 18dB
Bass Boost Frequency 45 Hz
Remote Control Wired Remote Punch Bass Control
Min. Impedance Unbridged 2 ohms
Description
Rockford has continually improved their Punch amps to offer more reliable power and better sound quality. Rockford`s Trans- ana (TRANSconductance Active Nodal Amplifier) MOSFET circuitry simplifies the current and voltage gain. The Punch series comes with Punch Bass, a remote operated bass EQ control that helps correct for missing low bass output in the automotive sound environment without adding excessive boost.
Punch amplifiers feature discreet surface mount technology (DSM) utilizing high-speed robotics to produce circuit boards that are more efficient, put out more power, and are less prone to unwanted noise. The supplied remote level **** can be installed anywhere for easy tuning. Punch series amplifiers feature a 12-dB/octave-slope crossover, variable between 40-400 Hz high- or low-pass.
The completely redesigned, focused mass die-cast heatsink has a sleek, rounded shape and features a removable chrome shroud that covers all connections for a clean, finished appearance. The top-mounted, illuminated RF logo even features built-in output meters for a little bling with your raw power.
Min. Impedance Bridged 4 ohms
Speaker Level Inputs No
Power Supply Topology MOSFET
Preamp Outputs Yes - 1 pair
3-Way Capable Yes
Protection Circuitry Overload
Connection 4 Gauge Power and Ground Connections
Input Voltage 14.4 volts
Fuse Rating 2 x 30 AMP
Power LED Indicators Yes
Fan Cooling No
Width 11 In.
Depth 13-11/16 In.
Height 2-7/16 In.
Will do Pay Pal
Pic 1
Pic 2
Pic 3
Will do Pay Pal
Type Component
Bass Boost 0 - 18dB
Description
3-Way Capable Yes
Fan Cooling No
Width 11 In.
Depth 13-11/16 In.
Height 2-7/16 In.
Will do Pay Pal
