zc question?????
Old Jul 2, 2006 | 05:34 PM
boomnn's Avatar
Default zc question?????
is there such a motor as a zc that is single cam???
if so is it a japanese model or what???
thanks neil
Old Jul 2, 2006 | 05:36 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: zc question????? (boomnn)
Yes 2 sohc zcs infact one is a d16z6 just diff name. The other is a a6 with a bit hotter cam and a tiny bit more comp ratio.
All Zcs were for no us models.
Old Jul 2, 2006 | 06:39 PM
E_F_9's Avatar
1st gen DOHC ZC - brown valve cover - came in 86-87 JDM Integra - will bolt directly into 1st gen CRX Si and 3rd gen Civic Si - will not bolt directly into 2nd gen CRX or 4th gen Civic.
2nd gen DOHC ZC - black valve cover - came in 88-89 JDM Integra - will bolt directly into 1st gen CRX and 3rd gen Civic, same as brown valve cover, however, it uses electronic advance distributor like 88-89 USDM Integra D16A1 - 1st gen CRX Si and 3rd gen Civic Si have vacuum advance distributor, so, to use it on 1g CRX or 3g Civic, you will have to do a lot of wiring changes.
3rd gen DOHC ZC - black valve cover - came in 88-91 JDM CRX Si and Civic Si - bolts directly into 2nd gen CRX and 4th gen Civic.
4th gen DOHC ZC - black valve cover - came in several different models of JDM cars 92 & up - is OBD1 - has Cylinder Position Sensor inside the distributor and will bolt directly into 92-00 Civics
SOHC ZC - basically the same as D16A6 (little more horsepower) - will bolt directly into 2nd gen CRX and 4th gen Civic.
SOHC VTEC ZC - basically the same as D16Z6 - OBD1 - will bolt directly into 92-00 Civic
Old Jul 2, 2006 | 06:40 PM
E_F_9's Avatar
googled
Old Jul 2, 2006 | 08:35 PM
boomnn's Avatar
sweet thanks for the info...
neil
barney_SI
Dec 6, 2009 09:37 PM
civic46
Jun 28, 2007 06:55 AM
b16er
Oct 20, 2006 07:05 PM
1badrex
18
Oct 10, 2003 07:23 AM
Ahknodd
May 1, 2003 07:47 AM
