Can AEM EMS P&P version handle 8 injectors?
Old Apr 18, 2002 | 05:21 PM
kidkutz's Avatar
Default Can AEM EMS P&P version handle 8 injectors?
Old Apr 18, 2002 | 05:22 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Can AEM EMS P&P version handle 8 injectors? (kidkutz)
It can handle 10 injectors.
art
Old Apr 18, 2002 | 05:27 PM
kidkutz's Avatar
Default Re: Can AEM EMS P&P version handle 8 injectors? (Arturbo)
i know the race version can...but can the plug and play version do that??
Old Apr 18, 2002 | 05:37 PM
ekb18c's Avatar
Race and PnP are the same box. Same comp!
Old Apr 18, 2002 | 05:38 PM
kidkutz's Avatar
Default Re: Can AEM EMS P&P version handle 8 injectors? (ekb18c)
how do i hook it up?
Old Apr 18, 2002 | 05:43 PM
b18bturbo's Avatar
you get the harness and set the inejctors in the ecu
Old Apr 18, 2002 | 05:45 PM
SiRkid's Avatar
Default Re: Can AEM EMS P&P version handle 8 injectors? (b18bturbo)
why you want soo many injectors?
hows the car? your in TO?!!? me too!
Old Apr 18, 2002 | 05:46 PM
kidkutz's Avatar
so how does this work? can i still use my stock harness (plug and play) AND purchase another harness for the secondary injectors from AEM? or do i have to use their custom harness for everything?
[Modified by kidkutz, 2:47 AM 4/19/2002]
Old Apr 18, 2002 | 06:54 PM
kidkutz's Avatar
TTT
Old Apr 18, 2002 | 07:12 PM
hondaswaper's Avatar
i heard from someone at AEM , that that computer was their Biggest mistake ever....
Old Apr 18, 2002 | 09:39 PM
ekb18c's Avatar
Why do you need 8 injectors for? If your planning to run 11's (as your sig says), you can do this with 4 injectors. You dont need 8 injectors!!!!
Old Apr 18, 2002 | 09:49 PM
Sonny's Avatar
25 Year Member
Default Re: Can AEM EMS P&P version handle 8 injectors? (hondaswaper)
Wow...informative!
Sonny
Old Apr 18, 2002 | 10:27 PM
gfreshman's Avatar
Default Re: Can AEM EMS P&P version handle 8 injectors? (Sonnyballs)
Hardly! Sometmes youhave to work hard to gain superb results.
Old Apr 19, 2002 | 05:40 AM
kidkutz's Avatar
i want to be able to idle my car nicely. i don't think i will be able to do this with 4 1000cc injectors. Wouldn't it be a good idea to run 4 primary 550cc's...and then another 550cc secondary injectors?
Old Apr 19, 2002 | 07:08 AM
pneuwirth's Avatar
The AEM EMS is probably the most innovative new product to be introduced to the market. My son and I own AEM. We are continuing to add dozens of plug and play applications. The product is successful when installed as we recommend and will perform better than any stand alone system with ease.
Old Apr 19, 2002 | 07:37 AM
stizzit's Avatar
Default Re: Can AEM EMS P&P version handle 8 injectors? (pneuwirth)
hmmm makes you wonder ...
Old Apr 19, 2002 | 08:19 AM
Default Re: Can AEM EMS P&P version handle 8 injectors? (stizzit)
the aem system is just a repackaged PRO-EFI computer........at an HIGH *** price....if you want to get somthing plug-and-play , buy a hondata, if you want a real standalone, the FAST (speedpro) can be had for 1300$ without the wide-band O2........how come Steph doesnt run one of these???
Old Apr 19, 2002 | 01:48 PM
ekb18c's Avatar
My vote goes to DFI Version 7.
Old Apr 19, 2002 | 02:34 PM
philo's Avatar
You can make a car idle fine with 880's. It's just getting the setup right. But if you really wanted to run 8 injectors with the PnP EMS you could. You would just use the unused pin locations on the EMS to pin the extra injectors in.
If someone at AEM said the EMS was a mistake, maybe the context was that it may have been released a little prematurely. 1/2 a year down the road it should be true plug-n-play product.
Old Apr 19, 2002 | 03:14 PM
pneuwirth's Avatar
Default Re: Can AEM EMS P&P version handle 8 injectors? (philo)
Philo,
I suggest you read the latest issue of "HondaTuner". It explains in detail what our system will do when tuned by the proper technicians and on a dyno. They also explain the pitfalls of not doing it properly. They were not of the opinion that we released the unit too early.
Incidentally, I believe we only advertised once in their magazine but can't remember when.
[Modified by pneuwirth, 1:00 AM 4/20/2002]
Old Apr 19, 2002 | 05:13 PM
PrecisionH23a's Avatar
because steph is sponsored by AEM
Old Apr 19, 2002 | 05:30 PM
pneuwirth's Avatar
Default Re: Can AEM EMS P&P version handle 8 injectors? (GudeH23a)
Steph is the ultimate perfectionist. He has requested some very special custom software changes that we are working on. His application is far from plug and play but not beyond our expertise.
Old Apr 19, 2002 | 05:38 PM
Arturbo's Avatar
Better than steak
25 Year Member
Even tho I have hondata, I really like the AEM EMS. All the features it has are just awesome. But its too late for me because I already purchased my hondata. AEM may have delayed the realease but its better they do that. AEM makes good products and it better that they perfect it, rather than sending it out to the customer and it having problems.
AEM EMS
art
Old Apr 19, 2002 | 05:51 PM
b18bturbo's Avatar
I know Ralphy AT DRT loves the unit. He making some good power i think like 630 or so on it. He really likes it over the DFI unit he was running.
Old Apr 22, 2002 | 08:27 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Talk about things you know.
The AEM ECU hardware was designed in house at AEM, the software was developed by GEMS. I paid 1300 (and I've seen them for less) for my EMS system and unlike a PRO-EFI system I don't have to spend another grand and 20 hours of my time just to install the sensors that you need to make your engine run.
