H22A Wiring Problem...
Hey guys, im swappin in a JDM H22A into my lude. all the wires are good, except the one that goes to the ECU. The P13 has 4 plugs, and my ECU harness only has the 3 for the P14. Will i need to get a new harness for it, are the wires there, or what? i know a lot of you guys have done this. Hope yall can help. thanks
4 plugs to the ECU? I think you may be mistakened, the P13 only uses 3 plugs to connect to the ECU, as with all Honda ECU's. Maybe we're talking about different things?
ECU Pin-outs for H22:
https://honda-tech.com/zerothread?id=918703
Wiring in VTEC:
https://honda-tech.com/zerothread?id=1004852
Wiring in VTEC:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq »</TD></TR><TR><TD CLASS="quote">Of course, but you'll get a soft code 36.</TD></TR></TABLE>
yep... fyi the "soft" code won't lite the CEL. It will just appear when you check codes. This is what I've got and it hasn't been an issue for me.
