b20 in 95 LS.
Old Jul 2, 2006 | 04:43 PM
B_CRUZ!'s Avatar
Default b20 in 95 LS.
B20 in my DC has been giving me headaches. It wouldn't stay on after it fired up unless you gave it some throttle. For the longest time I wasn't getting a code but today, in an attempt to bleed the cooling system, I was finally able to get a CEL. I got code 43.
Stock B20, obd1 LS intake mani, chipped p28 w/skunk2 non vtec program.
Since then, I have swapped out the 02, fuel pump and fuel injectors and I still get the same code.
I then borrowed a stock LS ecu from a buddy and tried it out. Now I get a code 14 for the IAC (EACV) - idle air control valve .
I swapped it out with another one and I still get the same code. I go back to the chipped ECU and I still get the code 43.
WTF do I do next?
Old Jul 2, 2006 | 06:46 PM
Diego Dangers.'s Avatar
whats code 43? might help starting from there.
Old Jul 2, 2006 | 07:00 PM
qfast817's Avatar
Default Re: (Diego Dangers.)
well do you have the right plug on it, not the ait plug
Old Jul 2, 2006 | 10:17 PM
B_CRUZ!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Diego Dangers. &raquo;</TD></TR><TR><TD CLASS="quote">whats code 43? might help starting from there.</TD></TR></TABLE>
43 Fuel supply system
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qfast817 &raquo;</TD></TR><TR><TD CLASS="quote">well do you have the right plug on it, not the ait plug</TD></TR></TABLE>
yeah I checked that tonight. it is the right plug connected. The IAT plug barely reaches the IACV sensor.
demael93
Oct 25, 2013 05:27 AM
1_slo_ef
May 8, 2007 05:27 PM
T3-T4TEG
Apr 19, 2004 01:16 PM
