oil pressure outlet???
Old Jul 2, 2006 | 03:09 PM
jdmteg96's Avatar
Default oil pressure outlet???
is there something called a oil pressure outlet on b18b's??? if so where is the outlet located out. already searched couldn't find any info. this is what raised the question... http://cgi.ebay.com/ebaymotors...wItem
Modified by jdmteg96 at 7:40 PM 7/2/2006
Old Jul 2, 2006 | 03:59 PM
Dartanian's Avatar
Default Re: oil pressure outlet??? (jdmteg96)
The oil pressure sensor hole is where you would get the oil supply for a kit like that. It is located a little bit left of the oil filter at the back of the block.
Old Jul 2, 2006 | 07:00 PM
jdmteg96's Avatar
Default Re: oil pressure outlet??? (Sleeper Style)
any clue what it would be called in a haynes manual? i have one but i can't seem to find what its called in there. anybody have any pics???
Old Jul 2, 2006 | 07:54 PM
qfast817's Avatar
oil presser sending unit, its on the left of the oil filter
Old Jul 2, 2006 | 08:05 PM
kenny rogers's Avatar
Default Re: oil pressure outlet??? (qfast817)
Is this to run to a turbo, oil pressure gauge, both? Like the other guys said, it is on the back of the block, next to the oil filter.
Old Jul 3, 2006 | 06:37 PM
jdmteg96's Avatar
Default Re: oil pressure outlet??? (kenny rogers)
this is to run ls/vtec
Old Jul 3, 2006 | 08:32 PM
qfast817's Avatar
i ran my ls-vtec there or you can buy a oil filter sandwitch from fast-turbo.com, it works better
Old Jul 3, 2006 | 11:07 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qfast817 &raquo;</TD></TR><TR><TD CLASS="quote">i ran my ls-vtec there or you can buy a oil filter sandwitch from fast-turbo.com, it works better</TD></TR></TABLE>
Yeah, I am using a Greddy sandwich adapter instead. I didn't want to take any chance of the fitting snapping off in the back of the block.
Old Jul 4, 2006 | 04:22 AM
jdmteg96's Avatar
has anyone ever had any problems using just the adapter instead of the sandwich. what could make the adapter pop out of the block???
tim120
Sep 7, 2006 04:55 PM
_gurusan_
Dec 20, 2005 10:41 AM
k_bster24
Apr 26, 2004 08:31 PM
hondapwr
Mar 11, 2004 02:43 PM
accordfreak
Jan 27, 2004 12:52 PM
