How to read Tire Sizes??
Old Jul 2, 2006 | 02:24 PM
Touch's Avatar
Default How to read Tire Sizes??
I used to know how to do it, but can't remember
I think it's width/ sidewall height/ wheel sixe. Is that right?
Old Jul 2, 2006 | 02:29 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: How to read Tire Sizes?? (Touch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Touch &raquo;</TD></TR><TR><TD CLASS="quote">I used to know how to do it, but can't remember
I think it's width/ sidewall height/ wheel sixe. Is that right? </TD></TR></TABLE>
Most tire sizes are expressed in this way: 205/50-15. There are other letter codes thrown in, but they don't affect the size.
In this example, 205 is the width of the tread in millimeters, the sidewall height is 50 percent of the tread width, i.e. .50 * 205 mm = 102.5 mm (50 is known as the "aspect ratio"), and 15 is the diameter of the wheel in inches (measured at the tire bead where the tire is mounted, so it's called a 15-inch wheel even though the outer dimension is bigger, usually about an inch larger).
Old Jul 2, 2006 | 02:34 PM
Touch's Avatar
Default Re: How to read Tire Sizes?? (nsxtasy)
thank you.
Whiteintegra
Feb 14, 2008 06:43 PM
ITR3189
Nov 9, 2007 12:34 PM
the.hamburglar
Nov 15, 2005 08:28 AM
sTraNdeD
Jun 10, 2004 11:51 PM
SleepnCiViC
Feb 6, 2004 04:46 PM
