Swaps able to do in a EF 88 Civic 4dr?
some of the easier swaps would be the LT5 DOHC made by Lotus, The W12 out of a Phaton and the one everyone and their granny has the RB25DET.
Or you might try searching and or using the F.A.Qs we spend hours making.........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMdc2teg »</TD></TR><TR><TD CLASS="quote">What swaps can my bro do in his EF 88 Civic 4dr?</TD></TR></TABLE>
I have an 89 civic 4 dr that i just swapped in a jdm b16 dohc. any engine that can go into a civic hatch or a crx will fit into a 4dr. any d-series engines are a direct swap, you don't have to cut or weld anything just change some wiring. the b-series is the same as a d-series except that you have to pound the drivers side frame in a few inches for the altanator pulley to have room. then the f,h,and k-series engines are a lot harder to swap into an ef. chop, cut, reweld, run new lines rewire a lot.**** like that
whateverdude
Aug 3, 2005 07:05 AM
