DRL Removal help 5 th gen
Old Jul 2, 2006 | 07:15 AM
teg969's Avatar
Default DRL Removal help 5 th gen
ok so basically my car is from Ohio, but since it came to CanaDuh, well it needed stupid *** DRL's
Im trying to get rid of mine, i pulled the fuse labbled DRL and they stayed on...
does anyone know, since these weren't plugged by honda, but prolly by some garage, how they would of plugged them? because there not using that fuse, or maybe there is a relay somewhere...i think its next to the steeering colum, do i just remove that?
thanks
1997 prelude base
Old Jul 2, 2006 | 11:26 AM
darkspector's Avatar
that all depends on how they wired it up
Old Jul 3, 2006 | 07:52 AM
teg969's Avatar
Default Re: (darkspector)
but for sure there must be some procedure that they follwoed, i mean there has to be a relay right?
Old Jul 3, 2006 | 11:50 AM
yes there will be... you just gotta find it, trace the wiring coming from the bulb side harness. Once you run into a relay..
Old Jul 5, 2006 | 01:42 PM
teg969's Avatar
thanks ill go check that out
Old Jul 5, 2006 | 03:08 PM
M@'s Avatar
M@
Default Re: (teg969)
if yours are like my OEM 4gen ones then you may be able to follow from the p-brake switch. Mine only come on after the brake has been released the first time. if they are on when the car is on then I don't really know what to say. I guess you say its origionally from Ohio so I doubt this helps, but maybe the origional installer had some sence to use the OEM setup.
Old Jul 5, 2006 | 08:31 PM
teg969's Avatar
Default Re: (M@)
ya thats what im thinking the OEM setup, but i looked under the dash and god dam...i have no idea which one is the DRL relay can anyone help?
thanks
Old Jul 6, 2006 | 04:55 AM
M@'s Avatar
M@
I know that on mine the p-brake switch won't always work, so i get a DRL light to indicate they are not on. Maybe you can just disable the switch and they won't turn on.
btw: I think the DRL on the 4th gen is kinda cool. I like to be different though.
Old Jul 6, 2006 | 08:50 AM
teg969's Avatar
Default Re: (M@)
which switch?
Old Jul 6, 2006 | 09:29 AM
maks's Avatar
Usually, US cars that come to Canada have a DRL Kit installed (can be purchased at canadian tire, autosource, or similar).
You can look in the store at the kits and their instructions. This will show you how to install them, and by the same token, how to remove them.
Hope this helps.
Old Jul 6, 2006 | 06:02 PM
M@'s Avatar
M@
its a switch operated by the brake
Old Jul 6, 2006 | 08:22 PM
teg969's Avatar
Default Re: (maks)
thanks a lot guys...ill try and see what i can do...
Joe19
Feb 24, 2019 11:48 AM
97BB6Type-SH
Nov 24, 2008 06:46 PM
polishprinze
Oct 15, 2005 03:27 PM
illusion
Nov 21, 2003 11:07 AM
orangecrush
Mar 11, 2002 12:43 PM
