honda tech peeps need your help!!!!!!!!!
i have a b16. today i was driving it and i heard a pop! and it sounded like a valve was rattling around..... well i needed to get it home so i said *&#% it and started to drive it home....well a minute or so after i started the car the noise went away and my oil light came on...(its full of oil)...could this noise just have been the oil pump???
thanx for the help
well here was the problem the oil pump gear......
<center>
</center>
Modified by killerB16A at 10:11 AM 7/10/2006
thanx for the help
<center>
</center>
+1 to ^^^^^, sounds like it could be serious and def get the compression tests and leak down tests....notice and smoke or anything comin from the crank case...maybe foaming or excessive oil?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highroller54 »</TD></TR><TR><TD CLASS="quote">you wern't even in your phone?</TD></TR></TABLE>
ha, totally saw that one coming :-P
It's vtec, not vtech - that's a phone company
IN any event, do as others said...a pop and a valve ticking noise doesn't sound good.... Keep the lookout for black smoke (oil) and keep an eye on ur temprature gauge, if there is something wrong with the oil system, u don't want to fry ur engine while taking it to the shop :-\
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerB16A »</TD></TR><TR><TD CLASS="quote">vtech......gotcha.
what kinda numbers am i looking for when i do this compression test today?</TD></TR></TABLE>
-.- "vtec" .... as for compression numbers.... hopefully 200psi all across
... or atleast consistent between all cylinders.
what kinda numbers am i looking for when i do this compression test today?</TD></TR></TABLE>-.- "vtec" .... as for compression numbers.... hopefully 200psi all across
here is what i got......165.....180......175.......175.....its not good
so i am now looking for a new engine
i am thinking about just getting a new b16 but not sure dont have alot of money
so i read up on the compression test i did the test when the engine was cold could this be why i got low numbers?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killerB16A »</TD></TR><TR><TD CLASS="quote">so i read up on the compression test i did the test when the engine was cold could this be why i got low numbers?</TD></TR></TABLE>
not sure.. but 170-180 is pretty avg on cars with 90k+ miles
u might want to do a leak down test and see what the % is... those number are pretty low... cly #4 is pretty bad.. but it is still some what of a constent... and my motor has less then 90k and nothing wrong with it B16A gen 2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">
I thought blue smoke was oil and black was running rich?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic »</TD></TR><TR><TD CLASS="quote">
I thought blue smoke was oil and black was running rich?</TD></TR></TABLE>
black is when your running rich, he just doesn't know what he's talking about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
about.</TD></TR></TABLE>
cool thanks, had me second guessing
. Mine has three times that and my oil pump gears didnt break....the previous owner proly drove it like he stole it.
